Author Topic: Here we go again  (Read 7564 times)
Offline SFTopic starter
  • Country: ad
Here we go again
« on: April 07, 2024, 06:44:07 pm »
Hi all,
I thought that this was a 1st April joke... It is not  :wtf::palm:
"Building the first highway segment in the U.S. that can charge electric vehicles big and small as they drive"
"Construction to begin on test bed in Indiana to develop wireless charging for electric vehicles traveling at highway speeds"
https://www.purdue.edu/newsroom/releases/2024/Q1/building-the-first-highway-segment-in-the-u.s-that-can-charge-electric-vehicles-big-and-small-as-they-drive.html
Are they flogging a dead cow again?
SF
Online SiliconWizard
Re: Here we go again
« Reply #1 on: April 07, 2024, 09:59:50 pm »
There's a truckload of money to be made there as long as you have low ethics.
Offline CatalinaWOW
« Reply #2 on: April 07, 2024, 10:57:43 pm »
At least this doesn't violate physical laws, the governors ignorant comments notwithstanding.  It is hard to see how it makes economic sense. It isn't obvious to me, one way or the other.
« Last Edit: April 13, 2024, 05:21:36 pm by CatalinaWOW »
Offline CaptDon
  • Country: is
« Reply #3 on: April 13, 2024, 01:55:44 pm »
It only makes sense when the numbers are crunched by the same government who thought consuming 900,000 gallons of petrol to produce 1,000,000 gallons of ethanol was a win-win positive outcome!!! Too stupid to realize the total consequences of having burned 1,900,000 gallons of total carbon footprint fuel or the absolutely stupid consequence of adding 10% ethanol to gasoline also generates a 5% loss in fuel economy!!! But I see government sponsored 100 tanker car ethanol trains come through our town every day. As long as some worthless piece of shit is getting free government money they will keep telling 'advisors' to the politicians that it is a win-win!! Look at our transportation secretary, he doesn't have a pilot's license or a CDL but enacts rules 'proposed' to him by tax dollar leaches and he doesn't have the personal expertise to filter out the noise!!! Your government and your tax dollars at waste!!! Kind of like when Powell was head of the F.C.C., he couldn't identify any component of an R.F. circuit but was in charge of the rule making concerning R.F. circuits!!
Offline Nominal Animal
« Reply #4 on: April 13, 2024, 02:15:21 pm »
In Iceland?!  (Based on your current flag.)
Offline mariush
« Reply #5 on: April 13, 2024, 03:12:54 pm »
I assume it's gonna be horrible efficiency
Powering using fixed lines above would be cheaper : https://www.wired.com/2017/03/running-delivery-trucks-trolley-wires-isnt-crazy-sounds/
I see just a couple issues with the above.. would have to be quite high up or you won't be able to do oversized (too high loads)  and at least in US you'd no longer be able to land on highways in an emergency.
Article suggests use near shipping ports... i can see trucks moving shipping containers from port to locations 20-50 miles around the port.
Billing for the electricity could be an issue, but I suppose some kind of black box could log when truck starts charging and how much it takes in and send info by sms/internet to the company that manages the particular segment of power lines... you'd have to trust nobody hacks those devices (or maybe random weight  scale places could also access the black box and check i guess, or put cameras on poles and have the black box in truck broadcast an ID to pair the photo with a black box id - any truck that pulls power and broadcasts no id means stealing electricity)
« Last Edit: April 13, 2024, 03:23:32 pm by mariush »
Offline CatalinaWOW
« Reply #6 on: April 13, 2024, 05:35:14 pm »
Overhead lines are cheaper for a limited routes in high traffic areas.  It all comes down to how many kilometers can be transferred per charging station.  If that number is large the wire costs of overhead will exceed the charging station costs.  Other factors that are either unknown or hard to determine include maintenance, weather issues, and route service.  For a simple example of how this affects cost compare a linear route between towns with a "node" configuration serving all roads in a town within within range of the charging station.  In the linear case wire cost rises linearly with route length as does charging station cost.  In the "node" case wire costs are proportional to town area, where charging station cost is not a function of the linear road distance, but something related to town radius and traffic density.   This simple example of the complexity still oversimplifies.  A wired solution allows essentially unhampered route planning within the wired network.  The "node" configuration requires periodic passes past the charging location, but does allow for "off road" trips into driveways, parking lots and warehouses.
One obvious thought is a hybrid solution, with the nodes being overhead wire routes instead of wireless transfer.
One thing no one mentions in these comparisons.  Many alternative energy solutions are facing headwinds for aesthetic reasons.  I am sure this is a factor in this case also.
« Last Edit: April 13, 2024, 05:43:58 pm by CatalinaWOW »
Offline CaptDon
  • Country: is
« Reply #7 on: April 14, 2024, 02:18:04 pm »
Living on the 'North Coast' of the U.S.A., Lake Erie region. Heavy rail traffic along the 'shoreline'. I was a Purchase Services Agreement (PSA) contractor to a locomotive manufacturer in the area for the past 12 years. Retired now. Sticking around just for the fun.
The following users thanked this post: Nominal Animal
Offline Marco
« Reply #8 on: April 14, 2024, 04:54:38 pm »
If you don't mind the kV voltages and obliterating some long wave spectrum capacitive could be doable.
Roads are expensive, electronics are cheap. Some metal film below the road surface and some electronics every 10+ meter will hardly make a dent on road costs. It's the Litz coils which make wireless charging roads expensive.
Offline Rick Law
« Reply #9 on: April 15, 2024, 06:33:25 pm »
Don't forget the maintained cost, both in dollar terms and in pollution.  Digging up the highway to do any electronics/electrical repair is not going to be cheap.  The cost goes up significantly in heavily traveled road.
« Reply #10 on: April 15, 2024, 06:39:34 pm »
Yes, but that makes money circulate. :popcorn:
Offline Marco
« Reply #11 on: April 15, 2024, 07:28:08 pm »
We have a lot of intentionally porous asfalt here, needs to be resurfaced every 10-15 years any way.
After surface grinding, grind some parts a little deeper to embed the foil and cables.
« Last Edit: April 15, 2024, 07:33:59 pm by Marco »
Offline EEVblog
« Reply #12 on: June 11, 2024, 11:11:44 pm »
Bingo.
The following users thanked this post: Heartbreaker
Offline NiHaoMike
    • Facebook Page
« Reply #13 on: June 12, 2024, 12:42:03 pm »
The simple solution is to only put up the lines above a toll road.
