Author Topic: Grants for Warp Drive Designs.  (Read 3059 times)
Offline coppercone2
Re: Grants for Warp Drive Designs.
« Reply #50 on: July 22, 2024, 08:41:39 pm »
I am often suspicious that "low volume" physicists rail on ITER but "high volume" physicists appreciate ITER. Its kind of like the 1 microamp guy vs the 1 amp guy.
Suprisingly, if you talk to particle accelerator people, there is usually a beef between the heavy colliders (high particle count / big stuff) and the high speed colliders (geneva). It seems the general public gravitates towards 'speed' being more impressive then volume. I personally think the volume people might be on to something, because if your making something for mankind to use, you need alot of it. There is value towards 'cheaper' transmutation.
I like this picture here
https://upload.wikimedia.org/wikipedia/commons/thumb/d/da/ITER_Tokamak_and_Plant_Systems_%282016%29_%2841783636452%29.jpg/1800px-ITER_Tokamak_and_Plant_Systems_%282016%29_%2841783636452%29.jpg
I have a bad feeling they might get something fundamentally wrong, like the geometry of something hard to make lol
2040 bet pool on which part of it will need to be redesigned . I think so long they get the pipes right it might have a chance
« Last Edit: July 22, 2024, 08:52:18 pm by coppercone2 »
Offline joeqsmith
« Reply #51 on: July 23, 2024, 01:39:00 am »
They have.  Cost overruns and schedule delays.
Offline Haenk
« Reply #52 on: July 23, 2024, 07:14:33 am »
I think you missed the point of ITER. Numerous people have already got their PhD from it. Did you think it was supposed to achieve something else?
Let me quote right from their webthingie: "ITER is the world's largest fusion experiment."
There you have it. It is an experiment, the goal is to figure things out, not to build a running power plant.
Online Andy Chee
« Reply #53 on: July 23, 2024, 08:03:27 am »
Almost 20 years in and what really do we have to show for the $$$ spent?
Consider this:
JWST, a much smaller project when compared to ITER, also took 20 years to get off the ground.
People at the 10 year mark would've also been saying, "almost 10 years in and what do we have to show for it?"
Offline coppice
« Reply #54 on: July 23, 2024, 09:01:35 pm »
The goal of most current experiments is to pass a PhD dissertation defence session.
Offline coppercone2
« Reply #55 on: July 23, 2024, 09:23:33 pm »
the JSWT was a engineering problem. the physics behind it are very sound, it was just complicated.
The physics behind the ITER are not that sound. IMO the one AFTER the ITER can be treated like a james webb! If ITER proves the physics, then you just need a deliciously complicated engineered system to make it high Q.
The JWST has questions like, will this linkage survive the vibration. is the material that the mirrors or whatever are made from not going to crack.will something not get cold welded in space and jam the mechanism or will some guy wire tear up.
The ITER has questions like "will this thing even possibly hold plasma". I don't think with the amount of knowledge we have on telescopes that you could call the JWST a physics experiment, just a engineering problem. The ITER is a physics experiment. I don't think they can even say that it SHOULD work conceptually. More like might.
Now I do agree that there are sub components of the ITER that are similar to the james webb space telescopes. The vacuum system, the heat load, the power supplies, the RF heaters, the piping, magnets and waveguide. Its very complicated and tricky but conceptually those subsystems work to bring the correct 'bias' to the reactor if you give the engineers enough time, its guaranteed to be in spec. But even if you build all that complicated stuff to spec, it might not work because there is basically a dynamic control problem with a unknown specification at the core. There is no guarantee that those sub systems will be the correct control parameters for a fusion reaction.
I would love to know what the anticipated possibly failure points are for it not working if you build everything right.
At this point, it looks like if you got a blue print of that design, it would have little comic book diagrams that say "maybe one of these will work here".
From reading the wikipeida page, with the section on additional heating, with how many... possibilities there are, I half imagined a crew of like 10 guys with acetylene rose bud torches heating up some pipe going into the reactor to try to get it to start lol
« Last Edit: July 23, 2024, 09:45:12 pm by coppercone2 »
Offline Alex Eisenhut
  • Place text here.
« Reply #56 on: July 25, 2024, 04:31:19 am »
Correct, that's the job of DEMO.
Offline joeqsmith
« Reply #57 on: July 31, 2024, 10:40:49 pm »
The following users thanked this post: MK14
