I just purchased anNanoPi-NE04 with power supply as it requires rather more than usual. I checked the output voltage under load and of course it dropped to just over three volts at three amps.
So I took it apart and found an unusual electronic component, a ballast gravity ballast that is.
A nice chunk of sheared off steel they even went to the trouble of plating it, obviously top quality ballast.
