Author Topic: You’ll love this... more Free Power  (Read 1996 times)
Offline SL4PTopic starter
  • There's more value if you figure it out yourself!
« on: June 19, 2020, 06:39:37 pm »
sigh :palm:
 I just saved you watching the 30 minute presentation that leads to this page...  LINK
The planet is doomed.  :scared:
« Last Edit: June 19, 2020, 06:44:45 pm by SL4P »
Don't ask a question if you aren't willing to listen to the answer.
Offline MrMobodies
Re: You’ll love this... more Free Power
« Reply #1 on: June 19, 2020, 07:11:22 pm »
and free TV too:
https://milled.com/bhg/succulents-you-cant-kill-Bdoc_YIOaKZnhxXP
On searching I see it just an antenna project.
https://www.dxzone.com/dx19161/n6tww-2-meter-halo.html
2 Meter Halo Antenna project by Mike Fedler with many detailed pictues and detailes homebrewing instructions so you can build your own
Category : Antennas/Halo
By N6TWW Hits: 3256 | Votes: 9 | Rating: 6.22
About N6TWW 2 meter Halo
The resource is currently listed in dxzone.com in 2 categories. The main category is Halo Antenna that is about Halo Antenna Projects. This link is listed in our web site directory since Wednesday Nov 5 2008, and till today "N6TWW 2 meter Halo" has been followed for a total of 3256 times. So far received 9 votes for a total score of 6.22/10
Featured Article
This link has been featured in the following Articles:
7 Cool Halo Antenna Projects You Can Make
Cool Halo antenna projects you can inspire to make you own halo for VHF UHF and even for 10 meters band
How to build a Halo Antenna for 2 meter band
This is a series of videos showing how to build an Omni directional horizontally polarized antenna for 2 meter single side band operation. This antenna is called a 'Halo Antenna' due to its circular shape.
You may find other interesting sites similar to this one, under the following categories:
 Antennas/2M - Antenna projects for 144 MHz
 Antennas/Halo - Halo Antenna Projects
On the reverse image lookup it looks like it got on Pinterest and now it is being used for adverts and all sorts of things.
Offline Labrat101
  • Regular
  • Renovating Old Test Equipment & Calibration ..
« Reply #2 on: June 19, 2020, 07:32:21 pm »
 :-DD
   Yes iT REALLy works I have been watching free Tv from the plant zarioide .    :-+
  There women are a little strange having 2 heads and talking to themself.   ( not that much different to here  :-DD)
 And the greeny gray tint on the screen I put down to low signal quality .
  Had a little trouble mounting it on the roof as there was this weird shaped craft that kept buzzing around  :scared:
   :popcorn:
 The coax is a little thin as well keeps melting when working at  115v @ 100A  :palm:
"   All Started With A BIG Bang!! .  .   & Magic Smoke  ".
« Reply #3 on: June 19, 2020, 10:04:09 pm »
Yes indeed, that’s why I followed the first link!
The antenna and coax had me intrigued how they could stuff it up.
« Last Edit: June 19, 2020, 11:35:56 pm by SL4P »
Offline Labrat101
  • Regular
« Reply #4 on: June 20, 2020, 05:43:03 pm »
Joking apart this type of antenna is not a new idea they actual work very well as reception  and if mounted correctly with a center
poll mounted @ 50ohm to the loop.
They make a nice low power transmission antenna on the 2mtr band  2watt  but getting swr of 1:1 is tricky .
I'm glade you watch the whole 30mins
other than it's assembled wrong . its only really good for a pigeon stand  :-DD
Never Know the pigeons maybe more into dropping a message   ... --- ...    :-+
« Reply #5 on: June 20, 2020, 05:49:12 pm »
it was the relationship between an obvious ‘antenna’ and free power that triggered me.
The pigeon hanger has another possible use... a lightning rod.
Offline Labrat101
  • Regular
« Reply #6 on: June 20, 2020, 07:31:13 pm »
Naa Lighting rod No . lighting likes copper yes.  with a vertical shaft with a ball tip.  :-+
 also the wire is a little on the thin side .  need a 2inch x 1/4 copper strap ..
 I have see lighting hit a radio aerial on a house roof .
   Thin wire acts like a large cheese cutting wire.  >:D
Stay with the pigeon stand its a little safer worse case your get pooped on .  :wtf: was that..
 and nearly environmental friendly   for the pigeons that is.
 :popcorn:
Offline bson
« Reply #7 on: July 01, 2020, 02:44:18 am »
So it's a Pigeon BBQ!
Offline Labrat101
  • Regular
« Reply #8 on: July 01, 2020, 09:12:31 am »
Yup maybe but a small motor on the shaft so it rotates slowly..  wind powered.  :-+
 more even cooking.
Of course with a solar mirror as it would not be FREE energy BBQ   :-DD
And a bucket underneath full of source of
Your choice finishing touches.
Eat when ready. .. yummy  .. smoky flavor..
« Last Edit: July 01, 2020, 09:18:07 am by Labrat101 »
