Author Topic: Anti static spray  (Read 2687 times)
Offline pamperchuTopic starter
Anti static spray
« on: January 30, 2019, 07:42:34 pm »
Found this old can of anti static spray, it helps prevent computer memory damage! you  can even spray it on you stuck up cat whose shedding hair  all over the place.
Offline Kean
    • Kean Electronics
Re: Anti static spray
« Reply #1 on: January 30, 2019, 08:17:18 pm »
Don't know about that one, but anti-static sprays are certainly available from reputable suppliers and can be useful.
Some are meant for use on carpet or restoring anti-stat matting.
http://desco.descoindustries.com/DescoCatalog/Floor-Care-Maintenance/Floor-Care/Statfree-Spray-Buff/81050/
Or for a static dissipative coating
https://www.mektronics.com.au/static-control/anti-static-chemicals-and-treatments/techspray-licron-crystal-esd-safe-coating.html
Offline Cyberdragon
« Reply #2 on: January 30, 2019, 09:17:44 pm »
It smells kind of like WD-40, whatever it is. :scared:
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline Raj
  • Country: in
  • Self taught, experimenter, noob(ish)
« Reply #3 on: January 30, 2019, 09:17:51 pm »
Sounds like a conductive powder inside of a high resistance carrier... Ain't sure
Offline Gyro
« Reply #4 on: January 30, 2019, 09:20:12 pm »
Diluted fabric conditioner works just as well (that's probably what it is).
Best Regards, Chris
Offline Cyberdragon
« Reply #5 on: January 30, 2019, 09:21:41 pm »
It's a clear sticky liquid (or maybe just cause the one I found was old).
might be... :-// Unscented though, smells a bit rank.
*BZZZZZZAAAAAP*
Offline helius
« Reply #6 on: January 30, 2019, 09:49:56 pm »
The active ingredient in these sprays is ditallow ammonium chloride, a quaternary ammonium compound (CAS 61789-80-8).
The ESD sprays are different, they are modified acrylic lacquers.
Offline Alexei.Polkhanov
« Reply #7 on: February 06, 2019, 07:55:47 am »
I have seen girls use it a lot in theatre to deal with static on big skirts used in a play that make them look like tight spandex after some time. Spray that they use works really well, but brand is different. Have you tested it?
Offline Halcyon
  • Global Moderator
« Reply #8 on: February 07, 2019, 01:58:59 am »
Yep, in the past I've used tap water with a few drops of dish washing detergent in a spray bottle. It works quite well.
Offline maginnovision
« Reply #9 on: February 15, 2019, 07:18:32 pm »
Used that sort of stuff to eliminate creaking from door seals.
