Brands aren't no better. My genuine made in India, motorola usb-c charger has started to give bearable amount of shock after 3 years of use (touching the shielding portion of the charger plug is enough to give you a shock).To make it worse, the whole phone's body is conductive.
My hp printer's adapter, lacks a ground pin.touching any metal portion like usb port gives you a shock, Until you connect it to a grounded computer.
My samsung monitor does the same thing too,if you touch vga plug,unless again, its connected to a computer.
None of them trigger mains GFI.
You know, when devices start to give you shock, it is really a good method to brain wash yourself to not use them.
Meanwhile, My zte charger and motorola charger, age 6, works fine but both are rated for 600mA.
They Really don't make things like they used to.
