The Qi-Technologies Qi-Max Cell™ 5G/WIFI/EMF Protection device uses scientifically proven and certified technology to provide you with a personal sanctuary against damaging EMFsThe Qi-Max Cell is the largest and most powerful EMF protection device. It uses the same technology as the smaller Qi-Shield device which has been scientifically proven to provide EMF Protection tested using a double-blind study at the BION Institute and certified by globally renowned TÜV SÜD.Enjoy the relief of being protected from harmful and damaging EMFs while at home or in the office. Including cell phone radiation, WiFi and other electro-magnetic frequencies (EMF).The Qi-Max Cell creates an EMF protection field of 50m radius (100m diameter) in width and 35m radius (70m diameter) in height, protecting your family, workplace and business against mobile phone radiation, WiFi, electrical frequencies, electro-magnetic frequencies. This is the most powerful Qi-Technologies product.The best way to set up Qi-Max Cell is at a central place in the home or work place at least 0.5m away from any electrical devices or ring mains. After only 24 hours your field of energy will be completely generated. The Qi-Max Business Cell is safe for you, children and pets.If you have a very large home or workplace you can use multiple devices to cover large areas or multiple floors of a building.Lasts for 10 years on a single charge and can be re-charged after this time.Designed, engineered and manufactured in Germany.
Globally Renowned Certification The Qi-Technologies Qi-Shield is certified by TÜV SÜD, providing a third-party endorsement by a globally renowned organisation. TÜV SÜD is a sign of quality assurance and safety in Germany which is globally recognised and respected as a trusted symbol of quality and safety. The Qi-Max Cell product uses the same manufacturing techniques and the same technology on a much larger scale than the Qi-Shield. View TÜV SÜD Report & Certification: https://conscious-spaces-ltd.myshopify.com/blogs/research/tuv-sud-certification-report-qi-shield-reduces-emf
Technical DetailsDimensions: 60.0 x 28.0 cmWeight: About 20kgMaterial: Copper Ring and Swiss PineEffective Protection Radius: 50mSafe Distance to Technology: 0.5mTime for Protective Field Effectiveness: After 24 hoursPower Source Comes charged. No electrical power or battery source needed.
ADVANTAGES OF QI RADIATION PROTECTIONDEEPER AND MORE RELAXED SLEEP FOR MORE LIFE QUALITYALL-ROUND PROTECTION FROM THE EFFECTS OF HARMFUL RADIATIONBALANCE OF HEART RATE VARIABILITYHEALING WATER THROUGHOUT THE ENTIRE HOME (Water is no good this will make it better)INCREASED LIFE ENERGY (ADENOSINE TRIPHOSPHATE, ATP)INCREASED PERFORMANCE THROUGH IMPROVED REGENERATIONLESS RADIATION-INDUCED HEADACHESBETTER COPING WITH JET LAG DUE TO PROTECTION FROM COSMIC RADIATION
