Ah yes AC right next to 12V output, brilliant.
Is it actually using a TOP224C chip, those are not that cheap. Also the tab is connected electrically, and I'm not seeing any sort of proper insulation in place to prevent it making contact with the case.
Whoever designed it appears to have some knowledge but not much safety wise, do you think it is a Thai design?
