Author Topic: Another CoolAir, with HydroChill Technology!  (Read 1465 times)
Offline StillTryingTopic starter
  • Country: Broken Britain
« on: August 11, 2020, 01:41:55 pm »
"All you have to do is add water into the tank, then plug it into a standard wall outlet or USB port, and then enjoy the cool air! You can then adjust the air temperature at will using the built-in numerical thermostat. Not only does it cool the air around you, it also completely purifies it."
With built in humidifer, - well yeah. ::)
https://airfreez.cc/cool/en/
Offline Cyberdragon
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline wraper
  • Country: lv
Re: Another CoolAir, with HydroChill Technology!
« Reply #2 on: August 12, 2020, 12:52:34 am »
CoolAir- the portable air conditioner selling out in the UK
(or other country in the title if you change the link accordingly)
The issue is it will not work well in UK. Evaporative coolers work well in places with low air humidity and UK is certainly not one of them.
