Seeing as the model is wearing something made from basically plastic with some thin aluminium layer on it that is slightly reflective, but in such small pieces that most RF is of a longer wavelength than the piece dimension, it will do almost no absorption or reflection at microwave frequencies or lower. You can put the RFID card in anywhere in that thing and it will still work, and if she has her cellphone in the standard place it will still work.
