The 2 micro USB connectors appear to be surface mount only, and not only that, the mechanical pads are only connected to the ground plane by thin traces; that is going to rip from the board after 2 or 3 uses. I would recommend to at least merge the 4 mechanical pads into the ground plane if you can't switch to a through holed connector at this stage. Thermal relief should never be used on mechanical or RF ground pads.
