Author Topic: Prestissimo Uno+: Uno w/ more I2C UART SPI ADC IO PWM  (Read 2826 times)
Offline researchTechTopic starter
« on: November 10, 2018, 05:41:34 am »
Hi Everyone,
Please check out are kickstater project:
https://www.kickstarter.com/projects/399880797/prestissimo-uno-uno-w-more-i2c-uart-spi-adc-io-pwm?ref=nav_search&result=project&term=prestissimo
Essentially is it an arduino compatible development boards for the new ATMEGA328PB microcontroller. It has the simplicity of the classic arduino uno while increasing resources available to the user.
There are more analog inputs, GPIO, PWM, as well as serial interfaces such as I2C, UART, SPI (two of each!).
Would love your support!  :)
Thank you.
Offline nikhilrt
  • Country: in
Re: Prestissimo Uno+: Uno w/ more I2C UART SPI ADC IO PWM
« Reply #1 on: September 13, 2019, 09:06:15 am »
NOTE: This message has been deleted by the forum moderator Simon for being against the forum rules and/or at the discretion of the moderator as being in the best interests of the forum community and the nature of the thread.
If you believe this to be in error, please contact the moderator involved.
An optional additional explanation is:
« Last Edit: September 19, 2019, 11:29:47 am by Simon »
Offline ledtester
« Reply #2 on: September 13, 2019, 11:38:08 am »
Hi Everyone,
Thank you.
That kickstarter project isn't active anymore - funding failed 9 months ago, and no new news since then.
Perhaps you can share the backers-only update made on 12/8/2018 about the potential relaunch with the rest of us?
Online ebastler
« Reply #3 on: September 18, 2019, 07:43:46 pm »
Not likely, since the OP has not been back to this forum since November 2018...
