Author Topic: SMD reflow test board - interest?  (Read 3527 times)
Offline bit.cyberTopic starter
    • lagrangianpoint
« on: April 01, 2017, 12:13:39 pm »
Hopefully this is being posted in the right category - here goes...
After expending some effort to convert a toaster oven into a solder reflow oven I'm now considering how to test/tune it. Yet I'm unable to find suitable test boards, with stencil, components, etc. So, I'm going to look to design up a couple of boards and batch produce them if there's demand. Thus to the question: general level of interest for such a kit?
The cost would be minimal'ish - that's the point, particularly if they'll be junked - let's say $15-20 with everything (although I haven't run the full numbers). Bulk ordering should make this possible.
I have a couple of designs in mind: a 'junk' test board with sample components, but otherwise doesn't do anything. Then a design or two could also serve a useful purpose, of course assuming the reflow works, e.g., a bidirectional level shifter board - 5.0 V to 3.3 V - or whatever (I'm always looking for one of these and have to order it from Sparkfun or whomever).
Thoughts?
(For the record, I did find a test board from Beta Layout - http://www.beta-layout.com - but the shipping was EUR20 for a EUR14 kit. Definitely defeats the purpose. I would just be posting anything, which is significantly cheaper.)
Just hanging around... (And do visit lagrangianpoint.net for the latest interesting projects underway)
The following users thanked this post: cgroen
Offline ebclr
    • lagrangianpoint
Re: SMD reflow test board - interest?
« Reply #2 on: April 01, 2017, 03:01:12 pm »
I would totally agree with "not worth to reinvent" the wheel! There just isn't any economic sense.  :-+
However the "wheel" I'm thinking of here is to primarily be able to test my home built reflow oven, without ruining some more expensive boards/components that are ready and raring to go. The mention of something useful was in relation to if everything does work out then to have something other than just a board that makes it's way quickly to the bin. Apologies if this wasn't clear.
Anyway, good to hear your thoughts.
Offline daveatol
« Reply #3 on: April 03, 2017, 12:55:44 am »
Just reflow some of your PCB coasters with a few cheap parts on that fit the footprints
    • lagrangianpoint
« Reply #4 on: April 03, 2017, 10:13:14 pm »
Firstly, thank you for all the suggestions for useful suggestions.  :clap: Secondly, oh crap - where do I start!  :scared:
So basics first: boards that are generally 20 mm x 10 mm or alternatively 40 mm x 20 mm. With headers at the standard pitch of 2.54 mm (100 mil), so suited toward breadboard work.
(While I do a lot of arduino development I agree that not everything has to be a shield. My last project was based on Arduino Minis, so hardly shield material... e.g., check out a front panel board I produce at: http://lagrangianpoint.net/product/programmable-load-front-panel-pcb/)
But after this, I'm not sure where to start! I like the sound of the "PCB antenna or antenna connector and preamp / filter" - that should be a challenge, but I should be careful as I don't really have the test gear to adequately test it.
As for a thermocouple board, I like the idea - particularly given my base level multimeter (Fluke 117) and even my Agilent multimeter (33401A) don't have a temperature input. Always the way, a feature missing somewhere and one wishing they'd spent the extra dough. Ah - but maybe there's the idea...
All are tempting...
