Hi Ranayna,
Thanks for your comment I will try to answer all of your questions:
1. I just measured the active idle power consumption of three PCs from different generations (All with “Balanced” power plan). These are the results (measured 30 minutes after power-on, with no HDD activity):
CPU: Intel Core2 Quad Q9550
Chipset: Intel G41
Accessories: Nvidia GT 520 (passive refrigeration) graphics card.
Idle power consumption: 84.3 W
CPU:CPU: Intel Core i5-650
Chipset: Intel H55 Express
Accessories: Nvidia GTX 760 graphics card.
Idle power consumption: 112.3 W
CPU: Intel Core i9-9900K
Chipset: Intel Z390
Accessories: Nvidia RTX 2060 SUPER graphics card. 5x 3.5’’ HDD.
Idle power consumption: 115.8 W
In addition, Wake on LAN/WIFI implies disabling the motherboard energy saving features (at least on all motherboards I have seen), in comparison, PC Manager have a power consumption of less than 0.5 W. The device also adds some functions that WOL are not capable of, such: crash detection, errors detection, etc.
Fortunately, this also works for non-disciplined users
2. Yes, the device is meant to keep it on continuously. It feeds from the computer’s standby power rail of the PSU. The remote functions are not available without Wi-Fi connection, but it can still act as a standard Front Panel’s LEDs and buttons (with log), and as all the inputs and outputs are reversible, it could be used on test assemblies, etc.
3. The Wi-Fi connection can be made using the Android app (The phone first connects to a network created by the device, and sends the Wi-Fi details via the app, so the device can connect to your Wi-Fi), or using a MicroSD card. It supports 2.4 GHz band (5 GHz band is not supported) in all standard Wi-Fi channels (limited by specific countries legislation).
4. You can check this function compatibility In the Kickstarter campaign or in PC Manager’s website (
https://www.pc-manager.net/en/compatibility/). I cannot speak for HP, DELL and other branded PCs, as they barely follow any standard in this respect. But there is still a lot of motherboards (including new ones, like the Asus ROG Z390-F I have) that still support beep error codes.
5. This function works by installing a very simple program that performs an HDD read/write every “n” seconds, then the PC Manager device detects this signal (HDD LED). If the PC Manager does not detect this signal, then notifies you (or it can be programmed to restart the PC automatically). Only for Windows, at the moment, although it wouldn’t be hard to implement it for other operating systems.
6. The signals are probably compatible, but it wouldn’t be reasonable to mount it on a laptop. Probably you’ll have to invest thousands of € on a laptop to compare it with a € 600 desktop computer (even more with a proper desktop workstation), for that reason there are still a lot of users that prefers to work with desktop computers.
Yes, maybe the ideal would have been 5 years ago, but apparently there are still a lot of desktop computer sales (
https://www.techspot.com/news/83094-pc-have-dead-now-but-somehow-alive-kicking.html ).
I hope to have answered all your questions. Thank you again for your comment.
