Author Topic: Pika Power Supply from TikStation  (Read 13192 times)
Offline wissaTopic starter
« on: December 12, 2022, 02:58:40 am »
https://www.crowdsupply.com/tikstation/pika-power-board
Hey everyone, I wanted to share with you a new power supply solution that I've been using for my DIY electronics projects. It's called the Tikstation Power Board, and it's been a game-changer for me.
One of the things I love about the Tikstation Power Board is its compact size. It's only 2.5 x 2.2 inches, so it's small enough to fit in the palm of your hand. This makes it perfect for taking with you on the go, or for using in tight spaces where a larger power supply would be unwieldy.
Another great thing about the Tikstation Power Board is its versatility. It can be powered by a 9V battery, a DC power supply, or a USB port, so you have plenty of options for how to power your devices. It also has multiple output options, including a 5V USB port, a 3.3V power rail, and three sets of 3.3V/5V jumper pins, so you can easily power a variety of different devices.
I also appreciate how easy the Tikstation Power Board is to use. It has an on/off switch and a power indicator LED, so you can easily control and monitor the power supply. It also has a built-in voltage regulator, which ensures that your devices receive a stable and consistent source of power, even if the input voltage fluctuates.
Overall, I'm really impressed with the Tikstation Power Board and I would definitely recommend it to other makers and DIY electronics enthusiasts. It's a great tool to have in your arsenal, and it's really helped me to power my projects with ease and reliability.
Offline PlainName
  • Country: va
Re: Pika Power Supply from TikStation
« Reply #1 on: December 12, 2022, 04:36:10 pm »
You missed a phone wireless charging pad :)
Looks like a well thought out project which covers almost all the bases for this kind of thing. Hope it goes well for you.
