Hi group,
I think this is the most interesting picture on the kickstarter campaign:
How they thought they could display that teardown picture and not have people see there is no vacuum system is beyond me
An interesting thought experiment:
A cheap way to create a vacuum in a chamber is to inject steam to displace the air and then condense the steam. Not that this is a viable method for the job of drying clothes. First there has to be valve to let the air out; that isn’t too hard to accomplish. The big problem is that the steam has to be cooled in order to make it condense. Where could they put this heat energy? Well, the clothes could be heated to make them dry faster, so heat the clothes with steam.
From a marketing standpoint this looks like a winner plus a claim of (elusive) “energy savings” by using the steam to do two things.
But wait, what about the steam condensing and adding water to the clothes that are supposed to be drying? The marketing wank answer is that they are under a vacuum and heated so drying so much more efficient. (Cue Dave’s fail button sound here, WA, Wa,wa) The Morus marketing people obviously don’t understand equilibrium, such a concept doesn’t seem like it has enough profit margin. So there is equilibrium of steam that was injected to make a vacuum and water vapor evaporating from the clothes; there doesn’t seem to be any energy savings with this model.
Then there is the bonus feature of a tray that collects all of the condensed water. There seems to zero heat pump components in the picture and Peltier junctions are anything but efficient against the heat of vaporization for water which needs to be removed from the vapor to condense it into water.
