First video, at 10 to 11 seconds, and again at about 15seconds.
IR images are very slow. Then changes to visible and the update rate seems fine.
IR appears to be frozen during the switch to/from visible
The user puts their finger in front of the device to grip it, finger nowhere near the Mu lens assembly, but covers the phone's own visible camera lens, and the image on the phone is obscured.
There is a
large distance between the phone's lens, and the Mu lens, however the visible and IR images seem to be very closely aligned.
I'm surprised that this is not evident in the visible image, I would have expected it's update rate to be quite sluggish due to the processing that must be necessary to get decent alignment?
If you look at for example, the FlirOne, they use their own visible camera, situated right next to the IR camera, as close as they could physically get it, not miles away, and even they get misaligned at close distance.
