Found another one:
https://www.indiegogo.com/projects/tcharger-the-next-generation-wireless-charger#/story
Wireless charging over 30 feet at 2Amps...
They should have at least faked the research papers. The first paper they linked, "Design and Construction of Wireless Power Transfer System Using Magnetic Resonant Coupling", shows a graph on page 4 where transfered power goes to zero for distances greater than 20 cm. The second paper has no experimental data at all, and I stopped reading the 3rd paper, which is an article of Tesla with his experiments where he claimed it is possible to distribute energy all over the world without wires. So why does the campaign limit it at 30 feet? It could charge your mobile phone within miles radius of the charger ![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
Haha, indeed :-) And if you search for the word 'distance' in the other documents, you'll find roughly the same value.
Unless you use a 1m diameter coil...
And there's no mention at all on how to position the receiver coil towards the transmitter coil.
Perpendicular? Parallel? It all seems to work ;-)
Bogus...
They recently posted an image where you can see a simple solenoid inside the transmitter
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Way to make it work at each angle. Also I wonder how could you prevent 100 cellphones harvesting energy from the system?
Uh there are so many hilarious details but I want to share something different with you. If you scroll down the comments section, you will see a guy named 'Evgene Ilchenko' commented on the project. Also, if you look up for scicorn ltd. from this site:
http://www.checkcompany.co.uk/company/08894073/SCICORN-TECHNOLOGY-LTDYou will see that Evgeny Ilchenko is the manager of this company. What a coincidence. If you go to the Evgene's indiegogo profile:
https://www.indiegogo.com/individuals/10543643/campaignsyou will see another bogus project named smart cardio, with the campaigner name 'Ravel Banshin'. Tesla Charger's campaigner is 'Pavel Yashin'. Wow this is just shameful. Also Scicorn ltd shows a connection with Impasto ltd on the same site, which has office in seychelles. Seychelles? They use this islands for money laundering.
I emailed indiegogo about this, nothing but copy-paste response.
