1. take a standard wallet.
2. glue or sew on a metallic foil covering everything on the outside but the zipper,
3. profit much like this kick-starter probably will
or in this case they most likely will be adding the foil during the bonding stage so it sits between the 2 walls of the outside of the wallet, theoretically this leaves a small gap but still lives up to its name,
