So the long-awaited Lifx bulbs started being delivered a couple of weeks back...I got one, and a couple of things I noticed are that it is substantially larger than a normal bulb, but also that it runs very hot.
I measured the outside of the housing at 197F.
Considering the long discussion we had about the Rigol DP832 heat sink issue, I am curious what other think about this? To me, if the whole outer casing of the bulb is running at 197F (92C) in open air, the insides are substantially hotter considering the heat needs to get through the component to the board to the housing, etc. And since the whole outer housing is the heat sink, all the electronics are surrounded by and being cooked by that.
Seems like it would be a recipe for a short life.
Thoughts?
