Author Topic: tinyTesla: The Little Singing Tesla Coil Anyone Can Build  (Read 3525 times)
Offline shinymetalTopic starter
« on: July 20, 2014, 05:21:25 pm »
Hey EEVbloggers, I came across this Kickstarter project for a little Tesla coil kit: http://kck.st/1mNd5cF
What do you think?
Offline Halfdead
Re: tinyTesla: The Little Singing Tesla Coil Anyone Can Build
« Reply #1 on: July 27, 2014, 03:05:11 am »
I think it's really overpriced, but a neat toy nonetheless.
Offline CanadianAvenger
« Reply #2 on: July 27, 2014, 04:09:45 am »
This is the second coil from OneTesla. I was in on the first one, and am quite happy with what was provided. It came a bit late, but they communicated fairly well throughout. [they had an issue getting the metal torroids manufactured] I would expect this one to run much smoother, and have no doubts that they will deliver on what was promised.
Offline DavidGoncalv
« Reply #3 on: August 12, 2014, 11:25:35 pm »
Hello fellow Artisan's Asylum inmate! I will definitely check your stuff out - pickup is available, yes?
Offline Sigmoid
« Reply #4 on: August 14, 2014, 06:48:34 pm »
I don't quite understand why the MIDI interface... Wouldn't it have been simpler and more useful to just make it a generic speaker with a line in?
Offline bktemp
« Reply #5 on: August 14, 2014, 07:42:37 pm »
MIDI has several advantages:
Line in does not work very well because you can only switch the output stage on and off, so no analogue values in between.
Most tesla coil driver circuits overload the mosfets/igbts to get the highest possible power. Therefore it is necessary to limit the duty cycle. This is much easier when you generate the frequency yourself.
