Greetings folks.. I've created a Carbon fiber and billet aluminum high performance Raspberry pi case. As passive cooling cases go, it is likely the best you can buy. Overclocked to 1.5ghz you get no throttling even after 30 minutes. There is no thermal pad nonsense as it is perfectly machined with a flat surface that exactly fits the microprocessor and ethernet chip. As a bonus it has the high performance looks that no other cases can touch.
![](https://www.macsboost.com/macsboostwp/wp-content/uploads/2019/01/IMG_2687.jpg)
Follow the links and I have some videos and some thermal testing data.
Why is it so expensive? Real carbon fiber and a precision machined case isn't a low cost endeavor. I didn't cut any corners. I was tired of crappy cases. Of course there are cheaper options and everyone else has gone for cheap. We have gone for the win. #piday #raspberrypi #winning
Use coupon code "winning" for $10 off!
https://www.macsboost.com/product/mcpi-carbon-fiber-aluminum-racing-raspberry-pi-case/I've already made the investment and have them in stock now so no crowdfunding risk to you.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
