Author Topic: £100 analogue fibre optic audio lead  (Read 14600 times)
Offline fcb
    • Electron Plus
Re: £100 analogue fibre optic audio lead
« Reply #25 on: July 04, 2015, 04:12:26 pm »
When I was involved in analog audio over fibre back in the early-mid 90's, we mainly used FM to modulate the audio - it was very good, and we could multiplex many channels of audio.
I've also sent audio over fibre in much the same way as the LightLead - it also sounds very good, and if they have fixed lengths and no need to for an AGC, it will be good.  Will be at as good as using star-quad or a digital system - no, but it might have colourations that the end user actually likes (much like valve amps).
I've backed the project as I think it has merit, although I think there is a certain amount poetic-license applied to the KS promotional material...
Offline Yago
« Reply #26 on: July 09, 2015, 01:02:54 pm »
from the video "lets just switch to the lightlead and do SOMETHING SIMILAR", the mix sounds very different to my ears, boosted.
I though very much the same.
Only got a shite speaker here, but I swear not only is the eq different, there are reverb and chorus effects added to the sound for the light lead test.
Offline fcb
    • Electron Plus
« Reply #27 on: July 09, 2015, 04:47:20 pm »
I suspect that the single biggest (sonic) benefit of the lightlead will be the inclusion of buffer amplifier in the chain - guitar amps vary wildly in their input impedance and this has (IMHO) the most significant effect on the 'tone'.
It's pretty immaterial as the have raised about 2% of the total..
Offline LightLead
« Reply #28 on: July 26, 2015, 02:04:45 pm »
Offline fcb
    • Electron Plus
« Reply #29 on: July 26, 2015, 02:41:35 pm »
You quote on the KS page:
"We use a patented optical analogue technology.
No encoding, digitisation or modulation.
The signal travels down the fiber as light!"
What's the patent number??
Offline LightLead
« Reply #30 on: July 26, 2015, 02:50:40 pm »
Here it is, i think its already been pulled out on a previous post.
Light Emission Circuit
EP 2833568 A1
http://google.com/patents/US20150037047?cl=en
http://google.com/patents/EP2833568A1?cl=en
Offline fcb
    • Electron Plus
« Reply #31 on: July 27, 2015, 08:27:35 am »
Interesting Patent - so it's just a uP controlled active bias.
102dB S/N would be very impressive..
Offline coppice
« Reply #32 on: July 27, 2015, 08:33:34 am »
What would be impressive about 102dB SNR? Even with quite small signals, where noise is harder to control, 102dB is very mundane these days.
Offline fcb
    • Electron Plus
« Reply #33 on: July 27, 2015, 08:51:13 pm »
Agree, 102dB SNR is a mundane or even poor for an ADC/DAC or even a balanced audio signal - but not for a EO-OE system.
Offline LightLead
« Reply #34 on: July 28, 2015, 06:18:37 pm »
We are at 104db S/N
we are constantly achieving better results as optical technology advances.
David Holmes.
Iconic Sound
Offline LightLead
Re: £35 analogue fibre optic audio lead
« Reply #35 on: August 06, 2015, 10:59:52 pm »
Offline Richard Crowley
  • KJ7YLK
« Reply #36 on: August 07, 2015, 01:19:47 am »
There has been an interesting developement!
And apparently it will only cost you £10 to find out what that is!
Offline rthorntnTopic starter
« Reply #37 on: August 07, 2015, 01:23:02 am »
I think the development is a kickstarter special price of 35 quid.
Offline LightLead
« Reply #38 on: August 07, 2015, 07:28:50 am »
I was actually referring to the new design model going to the printers.... but yes £35 is also exciting!
Offline fcb
    • Electron Plus
« Reply #39 on: August 07, 2015, 11:08:34 am »
I'm an early backer of this KS.
IMHO your making a mistake dropping the price to 1/3rd - I don't think this is the main reason your KS is stuck at 5% of target. I don't think you've made or can make a convincing case for this product - it's niche and it's one more thing to go wrong (and has batteries in it which scares people).
At £35 you will be making a huge loss on this project as you'll have to make in the region of 2000 units - your BOM is going to be thick-end of the £35 and you'll have to consider hard tooling (certainly if you want to make more in the future).
So if you've got the money for hard-tooling, why not just make some aluminium tools and produce a smaller batch for the niche.
