Relatively interesting project. I see main challenge in maintaining an active community, with good working application examples. They probably should have designed antenna differently, at least changed RX spacing in elevation plane to increase unambiguous monopulse angle sensing. There are numerous commercial modules that copied
AWR6843ISK evaluation kit antenna arrangement.
update 1: Some other modules using similar chipset, search for AWR6843 / IWR6843:
