Hey gang, my name is Crt Suznik. I am currently studying electrical engineering in Slovenia.
I love science and frequently make electronics projects. The ones that require a lot of research and I feel will benefit people, I share on Instructables.
You can see some of my work here:
https://www.instructables.com/member/CrtSuznik/instructables/I usually buy test equipment and tools on Aliexpress or even make my own when ever possible. With my knowledge base constantly expanding, I have found that my newer projects could benefit not only the electronics community, but quite possibly the world.
I am working on power saving and power producing devices, which have life saving potential in parts of the world where power is an issue. My systems could even be used to power food production plants for a small fraction of the cost and thus potentially eliminate world hunger.
While I cannot guarantee all of my projects will succeed, would gladly share my work and help others.
Here is where you come in!
Advanced projects require more advanced tools, but sadly the tool I need cannot be made at home.
This is why I want to buy it. It's called an oscilloscope.
I want to buy this one to be specific:
https://www.batronix.com/shop/oscilloscopes/Rigol-DS1054Z.html?fbclid=IwAR10kYog-NRreCmR4ST2ytcZtKFbHAZYA2rm6lOQ6S83Q_hnuQEwr9Vks94#yoReviewsMost of you probably know what it is, but just in case, I'll explain. In layman's terms, an oscilloscope is a device that lets you see electrical signals. Having one would allow me to properly test every part of my projects so I can document them in great detail. In some cases having an oscilloscope is even crucial to successfully completing a project, because you need to see what circuits are doing. An oscilloscope helps and is an essential part of every electronics lab.
Any donation, however small will be greatly appreciated and while I cannot promise that my work will in any way impact the world, I can promise you that I will do my best to make it a better place for you and me.
If you would like to contribute to my cause, you may do so by following this link
https://fundrazr.com/91RqO8?ref=ab_07p8OeOf course you're welcome to share the link with your friends and family. Thank each and every one of you.
