FW is 1.7.3
I managed to start the FG, but with very low voltage. Ampl=1Vpp, Offs=1,5V, f=50Hz. If i go higher with the Offs, i get an error and can't measure anything...
And it appears to be a problem with the down-programmer, as you can see on the scope print screen. CH1 is the faulty DCP and CH2 is a good one for the reference (with same parameters in FG as faulty DCP)
