So I got home this evening to finding two boxes FedEx left outside my front door, left out in the cold all day for anyone to walk off with...
(Thanks FedEx, nice and safe)
However... I spent the evening building them, it just couldn't wait until tomorrow!
In short: MASSIVE CONGRATULATIONS to Denis + the whole Envox team. These have really exceeded my expectations so far, and I feel there is much more to explore.
If I am honest I was slightly aprehensive on the module assembly of what would be received after all the "drama" from the assembler. However: the units I have recevied look perfect, no visible faults, and seem to work well and be manufactured to a high quality. (Not tested under load yet). So thank you for going through all that to get excellent units shipped with the kits.
Packaging is really excellent; nicely thought out and very compact.
The units are brilliant and have 100's of features burried inside the UI, but at the same time, quick and clean to use + operate.
The interface feels very intuitive, snappy and smooth and all in all light years ahead of some products.
The comments below are either very minor nitpicks, trivial things, // constructive criticism or user error in myself not understanding how to use this properly yet.
They in no way detract from such a fantastic job you and your team have done. The list of positives would be 100x longer than the following list of minor issues:
Hardware + fixings:- I ordered identical two units, one had two untapped holes on the PSU top lid AC-DC plate. The other unit had all 4x holes tapped, so maybe this one slipped the net. Easily solved my end by running an M3 tap through; absolutely no issue.
- One unit was 4x M3 black countersunk screws missing; again no problem as had plenty on the shelf. Both units however did ship with 7x extra silver pan head screw for some reason.
- One unit was missing a pluggable front terminal block. If you can let me know the part number, I'll pick a spare up on my next Farnell/Mouser order.
- One unit display was flapping around in the breeze on one side. Re-fixed by re-clamping the holding nuts, but now it looks offset. I think I'll fit some M3 washers and shift it so it's clamped properly and central to the cut out.
The other unit was 100% perfect display, in clamping + position.
- Silkscreen on the front panel of one unit is a bit chiped / flaky in a few minor places. Again, perfect on the other unit.
Software:Possibly ignore all of these comments as I've only had a quick test with the shipped V1.0 firmware.
I'll updated to 1.3.2 or whatever is latest tomorrow and have a deeper play.
However:
- Manual fan control PWM settings has a crazy resolution. 0.005% increments when using the encoder to adjust
Maybe it's ok to limit it to 1% increments? I like the self-PWM calibration feature.
- On clicking "Encoder and UserSW" Options... there only appears to be encoder options visible. How do you change what the UserSW does? (More than likely user error on this feature!)
- There seems to be inconsistencies in the number of decimal places displayed. e.g. 5V displays as: 5.00V, and then 5.100V displays at 5.1V, is there any way to fix the number of DP?
- I have not calibrated my units yet, but when turned to 0mA set, they flicker between 0mA and -0.5mA quite fast. Again, might be an old firmware related issue, or is this normal behaviour? It's just slightly distracting in the background, no actual use problem.
Questions:- On output coupling mode:
When using common GND mode with 2x DCP405's and 1x DCM220... are all 4x GND's common? The GUI only shows the first 3x channels are linked, but I assume all 4x are?
- Could I reshuffle my modules to have 3x DCP405's in the same BB3?
I understand only coupling series/parallel applied to slots 1+2. But could I drop in another DCP405 into slot 3 for full functionality?
All in all, this is a really really excellent product and lives up to the excitement. Thank you so much; very much worth the wait.
I can't wait to have a more detailed play with it over the weekend + upgrade the firmware, and put it under load and use it on an upcoming project.
I'm hoping I can sell my DP832 very soon and these two units can take centre stage on my bench
Really looking forware to the upcoming modules you have in development and would like to expand more into this ecosystem to make some really useful test setups for prototypes we make.
All the best,
Dan
