That manual looks very good.
I gave the PDF a short read and noticed only a couple of minor things.
Page 2
Please note that AC power cord is not included
into with this kit.
Page 6
This is a recommended method because it is less likely to cause the bottom plate to deform in
the process
of leveling. Or shorter: deform during leveling
Remove the MCU module from the package and take care not to place
them it on the conductive surface
to avoid short circuits as it comes with a battery installed.
Page 7
In order to mount the front panel to the bottom panel, it will be necessary to connect the TFT display to
the MCU module first.
No , before first (I think
Page 8
First, identify the connector position on the MCU module and carefully place the black plastic lever in
the up position (Fig. 9) to allow
the display flat flexible cable to enter smoothly.
Do not
activate power on the MCU module without the display connected or with a loosely connected flexible display
cable. Doing so may damage the power supply of the display backlight located on the MCU module.
Page 11?
Last picture cut off, page number missing
Page 14
Continue installing the AUX-PS module by carefully inserting it from the back
, making sure that the
Standby LED and power switch enter its holes in the front panel.
Page 17
Improper page break?
First
activation power up and installation of power module
sPage 21
When the converters are attached to the mounting frame,
a the top cover should be placed over them as
shown in Fig. 30. Secure it with four screws (item M).
Page 22
Place the top cover with the
monitored mounted converters behind the rear panel and plug the AC power connector
into the AUX-PS module as shown in Fig. 31.
Page 28
Carefully fold the cables coming from the Mean Well converter and place the top cove
r on the enclosure.
Mind you, I am not a native english speaker, so take my suggestions with a pinch of salt.
