I was going to suggest (if it isn't too late for a board rev) having optional mounting pads for SMD fuse holders like Mike suggested (e.g. Littelfuse NANO2).
Would be great upgrade that people could do by cutting a couple of (otherwise fusible) traces and mounting these between R1 & SWA-1A, and between R1 & R9.
BTW, is R9 connected to the correct terminal of R1? Isn't that putting the uA range through the Kelvin sense terminal?
a fuse makes no sense:
1) The ultimate scope of this design is low burden, i.e. now 20mOhm compared to 70 mOhm of the old design.
2) R1 does not need a fuse, normally. It is rated for nominal 10A (1W) , 31A max, see Vishay specification.
But I estimate, it will desolder itself when > 500mW / > 7A are applied.
I doubt that the switch will survive such high currents.
For R1 the connection of R9 makes no difference, because R9 is 1000 times bigger than R1, and the current 1000 times smaller.
R9 should have been connected to IN- directly, but the chosen circuitry is easier concerning the switch and more precise.
Normally, R1+R9 = 10.01 Ohm gives an additional 0.1% error for the µA (10.00 Ohm) shunt, but Dave implied a "trick":
R2 = 10k is in parallel to the 10.01Ohm, thereby reducing the µA shunt again to exactly 10.00Ohm.
Frank
