But why buy THIS product
Er... well, I'm not. But if I were looking for something, if this is obviously well made and has a good spec, why not? Cheapest price isn't necessarily the overriding factor if you want quality, you know.
your system is overly complicated
It is? Not sure how it could be simpler, but perhaps I didn't explain it very well (there isn't much
to explain really).
Why not simply charge them both via the wall
That's what I am doing! Except I use one charger, and this particular charger because it fits in a switched multiway adapter unobtrusively, and can bung out serious amps to fast charge the pad.
I never thought that was complicated!
so why not write a script that deals with the drive referencing
Good lord, no! Once I'm down that route there would be no end to what I might feel like doing
The problem is simple yet without a simple resolution (that I know of). Windows gives a newly plugged in drive the next available reference, which on my system happens to be O:. So I plug in my backup drive and it gets O:, except for the
other backup drive which gets P: sometimes. My backup software will thus look at O: and P: for these particular drives.
If I have the phone plugged in it take up O:. Except if it's plugged in before Windows has booted, in which case it takes up L:, my first mapped network drive, and then my accounts won't work because the account data is on L:, which is no longer the network but the phone. But at least the backup would work!
If you think a script is easy to write to cope with all this, be my guest in writing it - I would no doubt be enormously grateful
Everyone knows devices charge slowly when connected to a computer
Do they? A techy might, but your average phone abuser might not. Even if they did, sometimes slow isn't a problem: if you get into work, say, and plug your phone in whilst you're there, it matters little if it takes half an hour or several hours so long as it's done before you go home. And, you have to admit, a USB slot in your PC is often much simpler to plug into that a wallwart over the other side of the room.
