The case is nice, and if they figured out a good way to put adjustable/replaceable tips on the probe while keeping acceptable performance, then that might be worth it to some people.
In the meantime, I've acquired a set of transmission line probes, 3 GHz and above, on ebay, for similar or less money, and I have built several.
500 ohms is low, I agree with really wanting 1 kohm, and really wish I could get more.
The comparison data seems sketchy to me. The $2k 0.99 pF probe is probably a FET probe with 100 kohm parallel resistance. I would take the comparison more seriously if they listed the probes to which they compared it. A picture of the setup used to measure the probes is just as important, otherwise the comparison is not very meaningful.
I do admit that even simple EM problems look much more impressive and are easier to sell to management if you have a nicely colored simulation
Finally, I would not be so quick to dismiss the importance of the coax cable quality. Just because it's rated for high bandwidth doesn't mean its good.
If the effort expended makes eventually results in a transmission line probe with better performance for similar money, that would be great, or if the price was more like $50. I don't see that the current iteration is much (or any?) better than I can do with a piece of high quality coax and a resistor.
John
