^^^ Edit: Damn you! Beaten to the punch! ^^^
“Now you can check on your kids anywhere in the house when you’re away. No obstacle can keep Aire away!”
Except a door. Doors will be pretty good at stopping Aire.
Also, they make a big deal about using it to check on the elderly, however most falls happen in the bathroom, where the door is also likely to be shut.
As for checking on pets, well, I don’t care how quiet they claim it is (or how little downwash it produces), I guarantee it’s still going to freak the hell out of a lot of pets. (High speed motors, especially ones with blades attached, produce sounds above human hearing.)
As for telepresence, I can’t imagine the battery lasts more than 10 minutes per charge for a drone that size. (I get 15 out of my Parrot Bebop, on a good day.) You’d be better off hooking a Raspberry Pi to a Roomba, with a camera on a stick attached.
I just don’t see any really valid use cases for this. For what it costs, you could easily place WiFi cameras in every room.
