Author Topic: Fidget Spinners  (Read 11915 times)
Offline JohnSL
Re: Fidget Spinners
« Reply #25 on: April 15, 2017, 12:47:16 am »
Sorry for being late to the conversation. I've been making molds using a hobby CNC (Taig) for about 10 years. Here is an example of the molded parts (glued together) that I think speaks for itself:
The handle in front is about 0.010 inches in diameter, cut with an equally small cutter. As you can see, the parting line is nearly invisible. Also injected with a bench-top machine.
http://trains.socha.com/2011/03/making-of-slag-pot.html
So I'm not going to argue how accurate my hobby machines are. But I will say that I can get excellent results. And this was done without ball screws, using software backlash compensation.
