Author Topic: Differential pairs!  (Read 4676 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
Differential pairs!
« on: February 01, 2018, 02:16:51 pm »
Right. what do I do? the written documentation is not the most enlightening. the video is second to useless and I'm left wondering what to do.
So I finally worked out how to declare two nets as pairs, I sort of worked out how to route differential pairs but it looks like i must set pins up to be on the right side as the differential router won't automatically swap a layer so that the tracks can cross ?
Offline voltsandjolts
Re: Differential pairs!
« Reply #1 on: February 01, 2018, 04:05:01 pm »
What bandwidth are you hoping to run your diff pair at?
e.g. for USB full speed you would probably OK with via crossover. For high speed, I dunno, but I'm a pessimist.
Offline Joel_l
« Reply #2 on: February 01, 2018, 08:54:37 pm »
I don't think the question was, should you it, as much as it was, how do you get CS to do it.
I played with this a little today, no progress.
« Reply #3 on: February 01, 2018, 10:22:54 pm »
The question is first of all 'should you' and then maybe 'how you' cross a diff pair. I typically do 4 layer boards that are not controlled impedance and do not have high bandwdth diff pairs. I would guess that Simon is in a similar situation. So, this method works for me:
Once you have decided what pattern you want to use for the crossover (one or two pairs of vias & position), place vias and set their nets appropriately. Use vias in both traces to match impedance as best you can and to provide a via pair that the diff route tool can 'snap' to.
Manually route the (very short) crossover section. Manually matching the trace lengths in this short section is not really a chore and not an issue for a low bandwidth diff pair.
Now use the diff pair routing tool to route the long sections of the pair - they will 'snap' to the via pairs of your crossover because you set the nets for those.
« Reply #4 on: February 02, 2018, 09:41:37 am »
For example, matched length / matched via crossovers with layer change and without layer change:
The following users thanked this post: 3db, mars01, ubbut
