Works fine for me.
The more I use it, the less I miss Altium Designer.
I find myself in the same spot. I have the opportunity to use the Altium Designer work license for whatever I do as hobby but once I bought CS I started to use it first because 'I gave money for it".
After a while I assigned a lot of shortcuts to my liking including for some capabilities for which there is no GUI in CS and found that I'm comfortable using it. Especially turning off and on the polygons (for that I have 2 shortcut keys as there is no way to make a toggle).
There are rough spots, e.g it's annoying me like hell that when adding components in schematic, they put the component name column the last, and I move it in the right position (first) the software move it back when adding the next component ... and others but overall it's an okeish software.
