Y'mean electrical type? Yes.
If it's a digital component, the other pins can be assigned input, output, etc. as well.
Analog pins should usually be set passive. Pin type checking (part of ERC) is really only meaningful in digital circuits. Passive is the default "doesn't matter" type.
