Author Topic: new searching problems  (Read 3525 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: July 25, 2018, 07:22:27 am »
So after much discussion about the malfunctioning of the search function in CS, now it has a new random behaviour: it won't work on schematics..... Only PCB's. How a program that has not changed exhibit different behaviours? This is a total joke.
Offline Kaziq
Re: new searching problems
« Reply #1 on: August 07, 2018, 09:52:49 am »
I had the same problem - the top search bar was showing only PCB components, but I found out that the Tools->Find command worked decent.
Then after some time I wanted to search a PCB component from the top bar, and it started showing schematic components too. Weird.
