The "Generate output" feature generates the BOM, Gerber files, schematic pdf, etc. It understandably requires quite a bit of setup and has allot of options. The setup is saved to the *.OutJob file so that the user does not need to repeat the process each time they generate outputs. However, the *.OutJob file is not portable between projects. This is a problem.
Many users will want to use an identical setup for every project, and when a different setup is required, it would be far more convenient to create this by modifying a existing setup rather than starting from scratch.
Is it possible to import/export the "Generate output" setup to/from a project? Does anyone else find the absence of such feature problematic?
