Author Topic: Your pet peeve, technical or otherwise.  (Read 602236 times)
0 Members and 14 Guests are viewing this topic.
Offline AndyBeez
  • Country: nu
Re: Your pet peeve, technical or otherwise.
« Reply #3700 on: July 02, 2023, 11:14:57 pm »
This evening, I thought I could write a computer's media playlist to an Audio CD and play this on the hifi. I have a functional USB CDRW drive, but not a single blank CD-R in the house! Not since 2015 apparently. Progress ???
Offline vk6zgo
« Reply #3701 on: July 03, 2023, 12:16:25 am »
Years back, when I got my first W7 desktop computer, the dumb thing used to crash at every opportunity.
I could get it back by returning to the original configuration, in the process, losing all the programs I had installed, & reactivating my pet hate of all time-Norton! >:(
The Internet was full of clever ways to get your PC back from a crash, except they required you to have admin privileges, which the "dumbed down" OEM version of W7 did not grant to the "unwashed".
I finally "bit the bullet" paid big bucks for a W7 disk from Dick Smith, & installed it, saying goodbye to the "e-Machines" crap forever, & never looked back!
The PC very seldom crashed, & was recoverable with a minimum of fuss when it did.
Much more recently, my ASUS laptop came with W10 "S" (for stupid or shit).
At least, they allowed me to send "S" to Hell where it belongs, with a minimum of fuss.
They did sternly warn me, that if I did that, I could never get it back-------but who would want to! >:(
Offline Bryn
    • mindsConnected
« Reply #3702 on: July 03, 2023, 07:01:28 am »
Another one that occasionally gets on my nerves is mice... the fact that mice nowadays don't last as long and experience wear and tear after a year or so. From the past eight years, I've went through six mice (two Logitech B100s, an HP X1000 and three Dell MS116s) and now I'm using a Kensington K72356EU. I'm trusting the reviews it got on Amazon regarding its longevity so here's hoping it'll do me a good number of years and not like six months like my last one.
It seems to me that mice nowadays aren't built to last... I mean, I had a Logitech mouse that did me a whopping 11 years (that I had since my first WinXP computer). I still miss it to this day :(
mindsConnected
Alternate tech forum for all... recently reopened (as of 15/9/24)
We welcome engineers also!
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #3703 on: July 03, 2023, 09:23:16 am »
hehe. You showing up in the cat thread and now complaining about mice isn't lost on this old cat.  ;)
I'm a trackball guy and there's a extensive thread on here that goes into much detail on procuring new switches much better than the OEM for my particular offending model. Depends on the model, but if you can get at the switches (and the case is screwed not glued) your favourite mice can enjoy eternal life.
iratus parum formica
Offline armandine2
« Reply #3704 on: July 03, 2023, 11:08:07 am »
endless multiturn  :'(
In a closed society where everybody's guilty, the only crime is getting caught - Hunter S Thompson
Offline PlainName
  • Country: va
« Reply #3705 on: July 03, 2023, 01:13:44 pm »
Go on, give us a clue :)
Offline james_s
« Reply #3706 on: July 03, 2023, 06:05:05 pm »
I still have one of the original Microsoft optical mice that I got over 20 years ago when I worked there, it's a bit yellowed and there's some wear from my fingers but it still works.
Offline PlainName
  • Country: va
« Reply #3707 on: July 03, 2023, 07:16:24 pm »
I had one of those (until I gave it away earlier this year). Looked pristine, mostly because it'd never been used since I discovered Logitech mice :)
Online SiliconWizard
« Reply #3708 on: July 03, 2023, 07:29:00 pm »
I have a Roccat kone pure which is something like 7 years old and it still works fine. A bit worn out externally but nothing major. Recently, the right click tends to be occasionally bouncy (triggers two right clicks instead of one), which is rarely a problem in most applications. But as I'm looking for a new mouse, I see it as a pretext to change.
I can't seem to find anything much I like though with recent mice. If anyone's got suggestions. I want to avoid wireless.
Offline PlainName
  • Country: va
« Reply #3709 on: July 03, 2023, 08:43:06 pm »
Why not wireless? I used to be a wired user because, games. But then I got wireless and the only difference I could tell was the cable not getting in the way any more. Even battery life is a non-issue: goes seemingly forever (well, a loooong time) and once a month I might remember to plug a USB cable into it when I go to make dinner or something. Worst case, it needs charging in the next 30 secs and then I just plug the cable in and use it as a wired mouse for a bit.
Having said that, non-rechargeable (that is, with alkaline batteries and typically Bluetooth) need a button press to wake them up if you don't move them for a bit. You get used to it, but it's a drag and I'd not use one of those for my main setup.
« Last Edit: July 03, 2023, 08:44:47 pm by PlainName »
Offline armandine2
« Reply #3710 on: July 04, 2023, 06:59:52 am »
when the trim pot has no end stop (and freewheels?)
Offline PlainName
  • Country: va
« Reply #3711 on: July 04, 2023, 10:28:36 am »
Ah, OK. Annoying, that.
Online Kim Christensen
« Reply #3712 on: July 04, 2023, 03:12:49 pm »
That's kind of normal. Usually there's a little click click click as you continue to turn it against the endstop.... Or, for example, did you mean that the 10k pot goes from 10K back to zero again?
Online TimFox
« Reply #3713 on: July 04, 2023, 04:26:43 pm »
Every linear multi-turn trimpot I have seen has a "lock thread" where the lead screw goes click-click-click at the ends of travel.
Otherwise, it would be easy to break the mechanism by overtravel.
"Helipots" (without separate lead screws) have definite stops at the ends of travel.
Offline vk6zgo
« Reply #3714 on: July 04, 2023, 11:53:58 pm »
That "lock thread" can fail, with the lead screw going click-click-click, but turning in the other direction does not reverse the direction of resistance change, with the resistance staying at the setting it reached before the failure.
Replacement is then the only "fix".
Online CirclotronTopic starter
« Reply #3715 on: July 05, 2023, 12:10:54 pm »
My stupid car wipers!
Use the squirters to clean the windscreen.
Then set the wipers going for several strokes.
Upstroke cleans the glass perfectly.
Downstroke allows airflow to flick some water off wiper blades and frames and back onto window.
Even after 10 or 12 wipe cycles there is still spots of water there.
 :rant:
« Last Edit: July 05, 2023, 12:21:32 pm by Circlotron »
Offline james_s
« Reply #3716 on: July 05, 2023, 07:28:22 pm »
Don't most multiturn trimpots do that? Usually there is a clutch mechanism that makes a soft clicking sound if you listen closely though.
« Reply #3717 on: July 05, 2023, 09:59:48 pm »
And when posts one’s pet peeve and it gets ignored by everybody else.
Actually I’m a great fan of recursion, so seeing that’s an example of such, I’m okay with it.  :)
« Reply #3718 on: July 05, 2023, 10:05:56 pm »
 :rant:
Yep. Try manually cleaning a window with the same motion - it's not really going to be very effective.
Offline PlainName
  • Country: va
« Reply #3719 on: July 05, 2023, 10:44:18 pm »
The bit that annoys me is you can't wash then wipe. It's always wipe then wash.
« Reply #3720 on: July 05, 2023, 11:03:41 pm »
It's the dumbed down world we live in. They are trying to be helpful when they make the wipers automatically go when you trigger the squirt. What was wrong with the pulling on the stalk to spray and then manually engaging the wipers once enough fluid was on the windshield?
Offline james_s
« Reply #3721 on: July 05, 2023, 11:14:10 pm »
I suspect the automatic wiping could be defeated by disconnecting the wire from the wash contacts to the intermittent wiper relay, at least on older cars like mine where everything is controlled by separate relays.
Online coppice
« Reply #3722 on: July 06, 2023, 04:43:08 pm »
This is not an issue with new cars. They either have the sprayer on the wiper arms, or they delay the start of the wipe until the sprayer has got the glass wet. The latter can be a little confusing when you aren't used to it. If you keep giving little shots of washing the wipers don't start. You have to hold the wash on for a couple of seconds.
Online themadhippy
« Reply #3723 on: July 06, 2023, 04:54:02 pm »
They are trying to be helpful when they make the wipers automatically go when you trigger the squirt. What was wrong with the pulling on the stalk to spray and then manually engaging the wipers once enough fluid was on the windshield??
Doing it there way ensures the wipers drag across the dry surface for a few seconds without lubrication,leading to a shortening of the wiper blades life,meaning you have to by replacements more often
The following users thanked this post: Bud
Offline AndyBeez
  • Country: nu
« Reply #3724 on: July 06, 2023, 04:59:12 pm »
That was my very first car driving experience, manually pumping the screen wash lever on my dad's car and then flicking the wiper toggle. Because if you tried to wipe before washing, the rubber blades juddered across the windscreen and my dad was not happy.
