I actually had decent experiences with Logitech mice in the past. But they let me down quite a bit in the last couple of years, both at home and in the office.
I privately owned an G5 refresh, that i replaced because it was utterly filthy after 5 or 6 years. That was on me alone.
Then i got a g500s, that started having doubleckick issues. I fixed that by replacing the button. Two years later i also replaced that one.
So two mice in more than ten years? Not a bad turnover in my opinion.
Then i tried a G502. And oh my... Whatever designer came up with those stupid sensitivity buttons left of the left mouse button
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
I disabled them, but they still annoyed me like crazy. I can't use that mouse.
I am now using a Roccat Kone Aimo, that has it's own issues. I love the formfactor, as it is very similar to the G5 series. But it does not have the freewheeling mousewheel, and it has RGB "running lights" that can only be turned off if you have the configuration software running...
Other than that i like it, it seems to hold up, but is only two years old.
At work, for the longest time, i used an M705. I loved that mouse, since it had a third side button that can be pressed with your thumb, which I remapped to middle mouse. And it had the freewheeling mousewheel. It ran on just a singe double A for a year or more. So what is not to like? Three of them broke before even the first battery was empty
![Broken! :-BROKE](https://www.eevblog.com/forum/Smileys/default/smiliey_scope_broke.gif)
And then i got another replacement. Still called the M705. But that third side button i mentioned? Gone
![WTF? :wtf:](https://www.eevblog.com/forum/Smileys/default/wtf2.gif)
That mouse now sits in the spares bin.
I am now using a M720 that uses bluetooth. My current work laptop just has a single USB A port, so no space for the dongle. It also has that third button, but the bluetooth sometimes cuts out, and the battery runtime is significantly worse. I now have that for about half a year, i will have to see how it keeps up. All in all i still like the mouse, and since i can only get Logitech mice at work, i am stuck with that model. Or i could get the MX Master, but that gives me cramps.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
So no great experiences with Logitech in recent years.
