I'd argue that ICE is not completely free of issues, at the time I went many parking lots had scores of electrical outlets to plug in the engine block heaters.
Yes; they do make it much easier to start the engine when the temperature drops below -10°C or so. They're only needed for a half hour to a hour before starting, though; they're not needed continuously.
I remember someone telling me they had trouble with diesel fuel gelling too although I don't know whether modern stuff still has that issue.
The stuff sold here has additives added that fixes those issues, and they're also available separately (typically in bottles to be mixed with 400 liters of diesel). This winter, there was a shortage of a key one, and its price shot through the roof. (I forget the exact details.)
There is no reason the same can't be done for battery packs
It is a slightly different issue, because the charge the battery can take or release is dependent on the temperature. It is not sufficient to just heat it when charging, you also need to heat it when discharging, so basically continuously. This affects the overall efficiency. And which cars already do this? Which ones have been tested to work in Arctic conditions in practice?
I do not know.Then again, I'm not in the market for a new EV, or any new vehicle, anyway.
