i got a new pet peeve : #%&&^ USB-C !
Every new laptop comes with the damn things. New docking station comes with the damn things. The end result is that none of my existing peripherals ( keyboard, mouse , space navigator ) can be plugged in. i need to buy a usb hub. old charging cables for iphone, watch and whatnot : same deal. i need ot buy adapter to convert 'classic' usb to that usb-c connector.
They can pump displayport or thunderbolt over that connector. yet another cable i need to buy.
For oodles of years HP has been using a standardized power plug. i got at least 10 of those 240 watt bricks laying around. Due to USB-C they now use a much smaller plug ( they use a kind of combo connector with a powerplug magnetically attached to a thunderbolt link for the dock ) Tthe dock still takes the classic power connector. the laptop has a different one. Problem is there are two versions of the dock : one with power (240watt), one without power (120watt). of course i have the 120 watt dock without power link. Power goes over the usb-c but is not sufficient to run the laptop full throttle (Zbook Fury 17 with an i7-10850 and a Quadro RTX3000). so now i can get another power brick for my second office ( i have two locations i work from. both have a dock and a power brick connected to the screens. i only move the laptop. no need to carry that stuff. now i have to.)
i understand the technical reasons and the reversability ( finally no more attempts to plug in a usb connector, having to flip it over and then flip it once more since you had it right the first time , it just didn't go in) but it is bloody annoying to have to deal with all the adapters and other crap since it is not backward compatible.
