Author Topic: Your pet peeve, technical or otherwise.  (Read 588411 times)
Offline SilverSolder
Re: Your pet peeve, technical or otherwise.
« Reply #700 on: April 01, 2021, 03:00:08 pm »
Blown plaster.seems its only the wall paper thats holding the very thin skim coat onto the walls.
Is that still used in current construction? Here plaster over lathe (thin wood slats with gaps between) was common up until sometime in the 1940s or so when sheetrock was developed and since then that has been used everywhere. There are still a few people around who do the old fashioned plastering but it's only used in historical structures.
In the US, wood framed houses with sheetrock are the norm.  In the UK, bricks are the norm (even in new houses).
Having lived in both countries, my experience is that UK brick houses are much more durable than the US constructions - there was almost no maintenance on my UK house, compared to my American one (new vinyl siding, new roof, new gutters, new windows, it's never ending...  the materials are simply not as durable as brick walls and tile roofs).
Offline james_s
« Reply #701 on: April 01, 2021, 08:51:53 pm »
For interior walls and ceilings though? Aren't those built of wood studs faced with some kind of panel even in brick houses?
Online themadhippy
« Reply #702 on: April 01, 2021, 09:34:58 pm »
In the uk house construction varies a bit,in general though  brick or some other type of block is used for the outer walls,theirs  normally  2  walls with a cavity between them,the outer wall will be your nice finished bricks whilst the inner wall can be rough  blocks . Internal partition walls may use some form of block work,or a frame work,either wood or metal, with plasterboard attached to it,The internal finish  on brick/block walls tends to be either plaster ,or plaster board fixed to the blocks by dot n dab.The plaster board itself might be plaster,or just a skim were the boards join,ceilings tend to be plaster board fixed to the joists ,again it might be fully plastered or just were boards join.
Offline james_s
« Reply #703 on: April 02, 2021, 02:52:43 am »
Is plaster board more or less the same as what we call sheetrock? It's a layer of plaster 3/8-1/2" thick sandwiched between a layer of heavy paper on both sides. You screw or nail it to the studs then tape the seams with paper tape and use joint compound to smooth over the seams and indents from screws/nails. After that it's common to spray on a texture, otherwise you have to do a much nicer job of taping and finishing before you paint or the seams will be visible.
Online Monkeh
« Reply #704 on: April 02, 2021, 03:22:31 am »
I think this justifies a new pet peeve: Typing a 13 word question with a 17 word description and a I'm tired of counting now elaboration instead of going to Google or Wikipedia and typing 'plasterboard'.
And yes, it's exactly the same product.
« Last Edit: April 02, 2021, 03:24:09 am by Monkeh »
« Reply #705 on: April 02, 2021, 03:41:00 am »
Yes except UK houses typically don't have studs like American houses, you often get bricks right behind the plaster / sheetrock.  Older houses tend to have brickwork even inside the house, separating the rooms.   Put it this way, you never see kids accidentally punching holes in the wall in UK houses the way it sometimes goes down in the US, lol! :D
Online Monkeh
« Reply #706 on: April 02, 2021, 03:55:01 am »
Yes, they do. Non-supporting walls are perfectly ordinary internally. Masonry for internal walls is usually to support the upper floors, roof structure and a central chimney or chimneys.
« Last Edit: April 02, 2021, 03:57:14 am by Monkeh »
Offline IDEngineer
« Reply #707 on: April 02, 2021, 03:59:11 am »
If there's no space between the plaster and bricks, where do the utilities run through the walls?
Offline perdrix
« Reply #708 on: April 02, 2021, 09:55:07 am »
Wherever they want to - they just drill a hole.  Otherwise run under floorboards between joists.
D.
Online themadhippy
« Reply #709 on: April 02, 2021, 10:34:52 am »
wiring is covered with capping or oval conduit  thats  nailed to the brick work,and then gets buried in the plaster.
« Last Edit: April 02, 2021, 10:37:14 am by themadhippy »
Offline Nominal Animal
« Reply #710 on: April 02, 2021, 11:07:13 am »
Another pet peeve: UPS drivers who stop in front of your house for ten seconds, not even leaving the driver's seat, just so they can claim they couldn't deliver the package.
« Reply #711 on: April 02, 2021, 12:47:30 pm »
Depends on the house, when it was built, etc. etc., I guess.  My house had only brick walls everywhere.  Built in 1933 and will probably still be standing in 3033!  :D
« Reply #712 on: April 02, 2021, 12:49:26 pm »
Exactly, you literally dig a trench in the wall to run cables, then cover with metal (or use conduit in the first place)
Online themadhippy
« Reply #713 on: April 02, 2021, 01:48:40 pm »
no need for metal,plastics perfectly acceptable,its only job is to stop the cable being damaged by the plasters trowel
Offline Syntax Error
« Reply #714 on: April 02, 2021, 01:59:37 pm »
An day cutting channels with a multitool and vacuum cleaner, followed by a day of making the channel invisible with smooth surface filler. Fun fun fun.
Another peeve; people who do block schematics that are backwards compatible with 1950s typewriters. Ever heard of MS Word?
Offline james_s
« Reply #715 on: April 02, 2021, 07:54:24 pm »
An inspector over here would have a heart attack seeing that. Seems like incidents of someone hanging a picture and managing to pound the tack right into a live wire would be common enough to be problematic. You'd never hit a wire like that if you were trying, but random events have a way of doing that sort of thing.
Offline james_s
« Reply #716 on: April 02, 2021, 07:57:27 pm »
My biggest delivery peeve are the FedEx drivers who set the package right on the edge of my front porch in the spot that is most clearly visible from the street and not protected from rain by the roof. I once saw a package delivered while I was at work and the driver set it in the one patch of porch that was already wet with torrential rains predicted for the day. I had to call my mother and get her to drive over to my house and collect the package which was already soaking wet. The driver could have set it 2 feet further back and it would have been fine. They seem to be unaware of the existence of doorbells, we've started calling FedEx the package ninjas.
Offline Bud
« Reply #717 on: April 02, 2021, 08:24:10 pm »
Here Amazon drivers never ring the bell. UPS and Fedex still do.
Online themadhippy
« Reply #718 on: April 02, 2021, 08:45:15 pm »
Were only supposed to run cables in "safe zones" but of course that dont stop people deciding they really must have a picture hung directly above a socket,or diy daves draping there cable diagonally across the wall to save a few inches of cable
« Reply #719 on: April 02, 2021, 10:27:43 pm »
That's why I like covering the cables with metal...  you have to try harder with the picture hook to make an impression, and you have a grounded conduit there to short the whole thing out with an almighty bang to teach a lesson!
Offline IDEngineer
« Reply #720 on: April 03, 2021, 12:39:52 am »
Yep, I second the james_s comment about inspectors and that scheme. Honestly it just seems dangerous no matter what the local standards may allow.
Speaking of metal coverings... here in the States we have these little metal plates with sharpened points that you hammer on the top of studs to protect pipes that pass through the studs. Again, this is to prevent penetration of a water or gas pipe with a screw or nail by a hapless homeowner. I'm not always a fan of building codes but in these cases they make a lot of sense.
EDIT: Here's a photo.
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #721 on: April 03, 2021, 12:44:38 am »
Hot should be above the cold.
iratus parum formica
Offline IDEngineer
« Reply #722 on: April 03, 2021, 12:51:08 am »
Maybe red is used for cold in that jurisdiction.  >:D
Offline Ed.Kloonk
« Reply #723 on: April 03, 2021, 12:58:03 am »
 :scared:
Offline Ed.Kloonk
« Reply #724 on: April 03, 2021, 01:03:22 am »
I believe that those plates are for the plasterboard fixers, really. They are the most likely to do damage.
Would like to have seen some silicone squeezed around the pipes to prevent water hammer.
