Author Topic: Your pet peeve, technical or otherwise.  (Read 570846 times)
Offline PlainName
  • Country: va
Re: Your pet peeve, technical or otherwise.
« Reply #4075 on: Yesterday at 03:35:51 pm »
Documentation in wikis.
Perfect example: FluidNC which has it's documentation hosted on wiki.js. The documentation is quite thorough and there is a lot of it, but you need an internet connection to access it. Should wiki.js decide they've had enough, the entire thing is lost.
If only they would give a means to download as html, pdf, something. It would be tempting to try scraping the site, but nowadays you'd be banned as an AI scraping bot or something, and wikis are generally a bit tricky to scrape.
The following users thanked this post: rsjsouza
