Author Topic: Your pet peeve, technical or otherwise.  (Read 588961 times)
Offline TimFox
Re: Your pet peeve, technical or otherwise.
« Reply #3050 on: January 20, 2023, 08:04:56 pm »
One way to increase the apparent size of a small-extent light source is a diffuser, such as ground glass or similar plastic sheets.
A listing:  https://www.edmundoptics.com/c/optical-diffusers/731/#
Have you tried anything like this to reduce your eye strain?
Offline Bud
« Reply #3051 on: January 20, 2023, 08:24:42 pm »
Yes I think you are on the right track.
And I think I may have figured out my problem.
LED lights in Cool white, that is 6500k or thereabouts, are too bright/intense. But warm white LEDs are ok and I tolerate them just fine. Provided I don't buy something that is too high powered.
Holy cheese, I would suggest dropping it right away to 4K and after adapting to it drop to 3K. And i do not know your habbits but one should take walks outside during daytime as well. We do not typically appreciate that natural daylight affects our health.
The following users thanked this post: bigfoot22
Offline helius
« Reply #3052 on: January 20, 2023, 09:10:43 pm »
White LEDs are mostly blue LEDs exciting a phosphor that produces the other colors to make light that appears white (but does not have the same spectrum as white light from an incandescent source such as the sun). Because blue light has physiological effects from its interaction with the sleep-wake cycle, the massive use of LED lighting can be regarded as a medical experiment.
Offline james_s
« Reply #3053 on: January 21, 2023, 06:55:40 pm »
My grandmother told me to "always keep your hand in" which meant that you should always keep busy right up until you can't physically do it anymore due to old age preventing you. She's now in a nursing home and hates it there, well that would be putting it too bluntly, she is very bored there.
Mine said roughly the same, and she did stay active. She was regularly out on her riding mower cutting the grass at 98 and always walked down the ~1/4 mile driveway to get the newspaper until the last week or so of her life. Use it or lose it.
Offline Bud
« Reply #3054 on: January 21, 2023, 07:55:01 pm »
Offline pcprogrammer
« Reply #3055 on: January 21, 2023, 08:05:55 pm »
... I know we’re not supposed to speak ill of the dead, ....
I have always found that to be so stupid. If someone was a bastard during his life, why hide it when he is dead. The fact that he died does not change how he was.
The biggest criminal, but at his funeral, "It was such a good person." Yeah right.  :palm:
Online PlainName
  • Country: va
« Reply #3056 on: January 21, 2023, 09:59:30 pm »
Perhaps because it is surely better to remember good things than bad things.
Offline Nominal Animal
« Reply #3057 on: January 21, 2023, 10:33:14 pm »
In the Sci-Fi novel Speaker for the Dead, Orson Scott Card describes one solution to the dilemma: someone to thoroughly but honestly describe the reasons driving a person, why they were the way they were, to bring true closure via understanding to the family.
Online PlainName
  • Country: va
« Reply #3058 on: January 22, 2023, 12:03:33 am »
That would be OK. It's important to remember that funerals and the like are not for the deceased but purely for those that remain.
Offline ebastler
« Reply #3059 on: January 22, 2023, 09:04:49 am »
I'm 100% fine and used to fluorescent which produces a light that is uniform and spread across a large surface area along the surface of a bulb. It could be that the problem is coming down to intensity and needing more surface area. [...]
My main room light is a 8w Philips Tornado CFL in warm white, I have no issues with it and it fills the room just fine, can use that for ages with no issues. Soon as  I plug in a cool white LED 5w into the same lamp on the same table in the same room, boom, migraines, even from just the secondary dimmed reflections from the walls. THAT makes me think that its blue light thats causing the problems.
The fact that fluorescent is by design a very very diffuse light source and spread across a very large surface area, basically the entire length of the bulb, could mean that its the combination of reflective surfaces and concentrated light sources from a small area, eg the diffuser on a regular LED GLS bulb, and the high concentration of blue light. But that still doesn't explain why I get eye strain from beige coloured walls reflecting cool white LED.
I don't see why an LED "bulb" would have a significantly higher emission per surface area than a fluorescent one. The scattering/diffusing surface area of an LED GLS bulb is not significantly smaller than the one of a CFL spiral.
It seems likely to me that the "cold" 6500K spectrum plays a role in your response to the LED bulbs you tried. Maybe coupled with a psychological effect, getting tense because you expect problems, which might make this a self-fulfilling prophecy?
If you prefer even illumination emanating from a large surface area, have you heard of lamp shades?  ::)
Offline ebastler
« Reply #3060 on: January 22, 2023, 09:29:27 am »
I have a lamp shade only problem is the half illuminated LED GLS bulbs shoot most if not all of the light up onto the roof instead of out to the sides so the lamp shade doesn't glow and further diffuse the light.
I was thinking of lamp shades made of translucent glass, plastics or paper, which are in the line of sight between your eye and the light bulb.
Also, for workplace illumination: Have you looked into the LED tubes which replace the large T5 and T8 fluorescent tubes? They should nicely meet your "large emission surface" requirement, and are an easy retrofit to the low-cost lighting fixtures you can get (or already have) for the T5 and T8 tubes. And in contrast to the original fluorescent tubes, the LED types light up immediately without blinking.
Offline SilverSolder
« Reply #3061 on: January 22, 2023, 11:10:25 am »
And the "other" type of LED bulb the ones with fake filaments don't help the cause for LED either because they last such a short period of time due to the lack of any heatsinking whatsoever.
LED is a failed product. You lose a led driver in an entire baton thats no big issue but it still affects the overall brightness of the device but you quickly lose half of them in some of the LED devices and you end up just shifting shit products onto the market especially in an economy where people mostly buy the cheapest nastiest stuff they can find, combine that with the fact that manufacturers drive the hell out of most LEDs however and you get premature failure of most LED light fittings. Or did everybody forget this when they all went gun-ho and bought up LED? Did drivers and LED life expectancy improve while I was stuck under a rock? I can't imagine any LED light surviving 50,000 hours however even if they did improve the reliability of them, which is what makes me weary of using them that and the migraines.
I dunno LED smells too much like a con to me. It seems to me like people are just buying it because its new and trendy and the companies making them con everyone into believing that they'll last forever and ever and ever and that they pull such little power from the wall, oooh woooow, gee whizz!
Half the time I think people actually like change for changes skake. Because it makes them feel better. But you still have the problems of ballasts and electronics as you did have with CFL. You still have the problem of early failures with LED. And there is the elephant in the room the fact that LED produces blue light then converts it into other colours using phosphors.
I would rather stick to fluorescent, its tested its mature tech its reliable and if a bulb goes you can swap it out easily for hardly any cost. If you were to hold LED lights up to the same standards of light quality as you get from Fluorescent you would go broke replacing entire LED fixtures just to make sure that they all produced the same light output and all still worked because you have to replace the entire fixture most times with LED, unless you use strictly T5 and T8 retrofits.
Doing all of the numbers just doesn't add up. People who own teslas know what I mean, ever priced an entire LED fixture just because of shitty design?
https://teslamotorsclub.com/tmc/threads/daytime-running-lights-drl-issues-what-options-do-we-have-in-nz.234560/
As an experiment, I replaced some of the regular incandescent bulbs in a long bathroom fixture (with 12 bulbs).  I literally cannot tell the difference between the colour and brightness of the LED vs. the incandescent bulbs from any angle in the room -  I was both surprised and impressed.  These LED bulbs look and work like normal bulbs, except the bottom inch or so is stuffed with electronics.  I think one of those would work with the kind of lamp shade you talk about?
Where LED fails for me is when used on a dimmer...  the colour doesn't change correctly when dimmed.
The light bulb industry has been a scam since forever (one of the first ever industrial cartels, agreeing among themselves to not make bulbs last too long).  Of course these days, making things not last too long is par for the course in every industry.  Burn the planet down for short term profits, is what these clowns are all about.  Another pet peeve of mine!
Offline TimFox
« Reply #3062 on: January 22, 2023, 03:04:04 pm »
You seem to confuse "brightness" with "color" for artificial light sources.
My guess is that your problem has to do with color (especially the blue part of the spectrum) rather than brightness or intensity.
Offline paulca
« Reply #3063 on: January 22, 2023, 03:56:42 pm »
Get your self a smart bulb.  Not an RGB one.  Just a white one that has color temp and brightness controls.
I find them very, very useful.  For example I have them setup, such that during the evenings they come on rapidly to about 50% brightness.  However, after midnight, they come on slowly over 5 seconds to 25% brightness and max warmth.
You can imagine how pleasant this is when both the upstairs hallway and the bathroom lights are configured like that.  No longer do  you have to be blinded when you hit the bathroom switch!
The slightly annoying thing is, I went a little futher and made the lights, if forced on during the day to be 100% bright cold white.  If you need the light during daylight it's for something that needs a lot of light.
However I used the solar panel out put being under 0.1W as my "night time" trigger... and I didn't add any histeresis. So, anytime I have the office light on during the dawn or dust hours the constantly gets brighter, dimmer, warmer colder.  Reminding me how lazy a hobby programmer I am.
« Last Edit: January 22, 2023, 03:59:15 pm by paulca »
Offline Zeyneb
« Reply #3064 on: January 22, 2023, 06:35:49 pm »
When your father is a bastard psychopath all you have of memories in your past is bad things. Then society has built up a rule whereby if you disagree and do not trust or listen to your father in any way you are further punished again by society, by your friends, family, neighbours, anyone who knows only half of the story and immediatley disagrees with your series of events in some way or just disagrees with you because of something that you've done while going through the emotional turmoil and destroyed life that your father has left you.
Its pure horror material and it happens all of the time.
This exactly happened to me.
EDIT: It's better to not have contact with family members than constantly getting those unmistakable signs they want to blame you for it.
« Last Edit: January 22, 2023, 07:50:34 pm by Zeyneb »
goto considered awesome!
Offline james_s
« Reply #3065 on: January 22, 2023, 07:43:30 pm »
I have quite a few of them now, I find the Philips Hue bulbs to be the best. They have white, variable CCT white and RGB full color versions. Unfortunately they do flicker at the 1kHz PWM frequency whch took getting used to.  I mostly don't notice it anymore but if I move my eyes with the lamp in view I see the flicker.
Offline CatalinaWOW
« Reply #3066 on: January 22, 2023, 08:39:11 pm »
The rules for corner cases should always be different than what is right for the bulk of the population.  Unfortunately there seems to be a trend now to force the corner case rules on everyone.  Somehow concluding that a modest harm to a huge number of people is better than a larger harm to a small group.
If we were really wise we could arrange solutions that harm no one.
The following users thanked this post: PlainName, james_s
Offline SiliconWizard
« Reply #3067 on: January 22, 2023, 08:53:38 pm »
Oh we could. But we probably won't. Problem is that many deciders (political leaders) have perverse tendencies (often through narcissism), and rejoice in the idea of harming others in some way.
It's rather well known and you'll find a lot of studies about that. One paper: https://www.researchgate.net/publication/279839204_Narcissism_And_Leadership_A_Review_And_Research_Agenda
(just in case some would think I'm just taking this out of my arse.)
Offline IDEngineer
« Reply #3068 on: January 23, 2023, 04:12:17 am »
"Somehow concluding that a modest harm to a huge number of people is better than a larger harm to a small group."
That's like somehow concluding that if one person has cancer, it's better if more people have it.
The goal should be to *minimize* the number of people affected. Simple chance says that some ills will befall some people, even through no fault of their own. We should seek to prevent that from spreading, not artificially penalize the otherwise unaffected.
The following users thanked this post: james_s
Offline jonovid
    • JONOVID
« Reply #3069 on: January 23, 2023, 04:40:00 am »
Right now it seems like the whole world is going psychotic and preparing for war.
I don't see a solution occuring anytime soon either.
the best conspiracy theories are true, it takes time to realize war , peace & politics is sometimes planned years in advance.
even ET has its finger in the pie that is the world economic forum, believe it or not.
Hobbyist with a basic knowledge of electronics
« Reply #3070 on: January 23, 2023, 05:18:43 am »
Speaking of the WEF, this year they've had a bunch of billionaires saying that capitalism is bad. This is getting fun. :-DD
« Reply #3071 on: January 23, 2023, 06:42:23 am »
The day these billionaires start spreading their wealth, I will start believing them  :-DD
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #3072 on: January 23, 2023, 08:11:50 am »
We have had Bill Gates in Sydney. Somebody tweeted a picture of his parked plane.
I thought what I'm sure Bill has heard many times..
"I thought it would have been bigger."
iratus parum formica
The following users thanked this post: pcprogrammer
Offline IDEngineer
« Reply #3073 on: January 23, 2023, 03:27:06 pm »
I remember way back in the 90s there was a fair bit of fanfare that his personal car was a modest Volvo.
Yes, but meanwhile he was lobbying the US Congress to pass the 25 year and "Show and Display" rules so he could get his imported Porsche out of quarantine. :) Gates is basically personally responsible for our ability to import otherwise non-US-marketed vehicles. The EPA and NHTSB are hyper-sticklers about non-US-marketed cars, even if those cars are identical to those sent to other countries (example: Canada). Spare some thanks to Gates and his resources for making some of those vehicles kinda accessible to the "free" citizens of this country.
Offline james_s
« Reply #3074 on: January 23, 2023, 06:32:50 pm »
Those laws are stupid. A person ought to be free to import any car they want from anywhere in the world regardless of what it is or when it was made. Obviously it's going to need to have things like compliant lighting if it's going to be driven on public roads but the amount of rules and limitations that exist are just ridiculous. There are relatively very few people that are even going to want to go through the effort to import some random car, it's pretty much only collectors and enthusiasts.
