If she really is the last one in the building maybe they will offer her a generous settlement to walk away early. That should at least should pay for the relocation etc.
Given the lack of response compared to what happened with Naomi Wu and Simone Giertz, I guess old ladies in engineering are valued much less than young women in engineering? Sad...
Given the lack of response compared to what happened with Naomi Wu and Simone Giertz, I guess old ladies in engineering are valued much less than young women in engineering? Sad...There he goes again.Get help, this obsession isn't healthy or productive.
uhh some people dont like working in sardine cans and running an effective business means you pay other people as little as possible and if you get the process down yourself then you shorten your supply chain demands. A skilled person can use much less conventional overhead like having production stop because a supplied decided to fuck up.. once you have alot of parts you buy you need a purchasing department that keeps things organized.... and a quality department
you get a sales call and you say hold up, let me quote you in 3 days after I verify 15 different parts sources? when someone asks to buy some shit you wanna get back to them as soon as humanly fucking possible with a YES.. and deliver, not wonder if people are gonna send you sharp fucked up brackets, tomb stoned PCB and have their laser cutter break down.
2000sqft is small for a work shop.
reasonably accessible table saw, mill, drill press, grinder, lathe, tool cabinets, a few work benches, laser cutter, pick and place, oven occupies all that real fast. add welding, electronics, burn in test area...
a lot of idiots can pack all that stuff real tight but its not good for cleaning, workflow or safety. yea I am talking to you buddy, with that spectrum analyzer 2 feet away from a bench grinder.
if you wanna get stuff done fast too, you wanna setup your production in a round robin fashion, not have to hire a mathematician to do complex analysis on what route to take. less stress and you can actually focus on doing stuff rather then 'juggling space'
Those two are the only other female tech TV show hosts who have publicly asked for help in recent history. (That I know of anyways.)
you need a big empty relaxing room for that shit , its mentally hard
and it stifles innovation and quality, if you need to climb on tables to plug in equipment ETC (you start to trust whats going on in your head more since its easier).
maybe if your really disciplined. given how much test gear costs it should be accessible and well ventillated
This has nothing to do with female or not. You're just inventing reasons to mention the Youtube ladies you obsess about again.
maybe if your really disciplined. given how much test gear costs it should be accessible and well ventillatedThere's a lot between climbing on tables and 2000 square feet.
challenge accepted
but really, once you work at anything other then low frequencies and low powers thats bull shit, and even then, you can start using space quick once you start making custom test fixtures, amplifiers, sensor interfaces, etc
as soon as you wanna test a more complicated system you need to add more equipment too, more power rails, more scope channels, more data loggers, more processing, more everything.... otherwise you expand without having test ability, which leads to uncertainty, which is bad.
like do it properly with enclosures that actually power themselves not some kind of crap you need to occupy a bench supply with..
if you are advanced different amplitude/power levels, frequency ranges, noise ranges, all occupy space. All the precise DC stuff is different then the low noise DC stuff then the low current DC stuff then the audio stuff and everything has those categories
and don't forget the calibrators.. low noise enviroment, etc (and thats just for up to HF because no one has the budget to do the same stuff with microwaves unless your really big).
You can fit an entire room with just bridges and standards EASILY.
then you get into stuff like mechanical test fixtures, thermal test stuff, ovens, etc......................... yea no I don't want to see a god damn 3 phase motor tested on the same bench as fucking precise RF equipment. Thats dog shit, you need a separate crude bench for that.
All I see is a shortage of money that requires me to pick targets.
i could fill a room to the brim with antennas.
fran tone also does audio equipment. That means you need a proper audio room (or various kinds) to test the sound in to determine realistic use conditions (i,e, stuffed up living room, small hall way, large halls, etc... thats the whole point of her business to find out what works and sell different solutions. You can't do good 'human precpetion' stuff in a limited test setting. you gotta know whats in your customers heads so you can explain whats going on (even stuff like the effect of windows, curtains, etc) and recommend a good solution to them. If your good you would even have furniture test standards to see what different environments you can setup for people.. someone might send you a picture of their living room and ask 'whats a good product for this'? You might end up making mock ups of furniture etc. And her work is supposed to be custom/artistic so the enclosures etc all need to match.. its like having some kind of interior decorator acoustic laboratory just to test the product. Someone likes the decour and their willing to spend to make it sound good even if its total shit for audio quality.. you gotta be able to solve their problem or you lose a customer. Turning your living space into a test area? not the best for your psychology.
Maybe its not at that level yet but you can always do more with space.
also most people say that a healthy business is looking to grow/expand capabilities to become the go to. If you don't have some kind of R&D its easy to get eaten or become marginalized.
The key to building a compact electronics lab that works well is to plan ahead. Put more power strip (PDU) outlets on the rack than you expect to ever need. Same goes with networking if you work on a lot of Ethernet connected devices.
That said, even in Silicon Valley (a place infamous for near record housing costs), a studio apartment actually offers quite a bit of space for an electronics lab. It's when it comes to making enclosures for the electronics that the space available suddenly might seem insufficient, but luckily 3D printers are a "good enough" substitute to a complete machine shop for a lot of hobby electronics.
I know of many other female tech TV show hosts that I didn't mention because they seem to have been doing just fine. Just mentioning that previously, when a woman in tech asks for help, it's not long before a lot of guys jump in offering to help her.
I know of many other female tech TV show hosts that I didn't mention because they seem to have been doing just fine. Just mentioning that previously, when a woman in tech asks for help, it's not long before a lot of guys jump in offering to help her.Don't play innocent, you're not fooling anyone. You take every opportunity to talk about the women you obsess over, which are generally opportunities you inappropriately invent yourself. Find help and work your problem out.
