Author Topic: info  (Read 2773 times)
Offline peterthenoviceTopic starter
  • rip the other half out put in a bread board
info
« on: July 11, 2013, 12:11:31 am »
what info would you like to have in a laminated sheet for reference if you could put any thing on it.
a craftsman multimeter, bk precsion scope
Offline Short Circuit
Re: info
« Reply #1 on: July 11, 2013, 12:53:57 am »
stretching exercises for the gym  8)
Offline Rerouter
Re: info
« Reply #2 on: July 11, 2013, 08:24:10 am »
all the relevant equations for magnetic and ac phase /  power with the values defined with units,
Offline Jon Chandler
    • Throw Away PIC
Re: info
« Reply #3 on: July 11, 2013, 11:34:17 am »
I have a bookmark collection of references like these broken down by category.  Makes it easy to locate "the best" when I need a reference.
The one laminated reference I do keep on hand has a drawing of the microcontroller circuit board I use for most of my projects with the port pins for every connector pin, LED and switch called out.
One handy thing on the back side, a table showing the limits for each variable type.
Offline madires
  • A qualified hobbyist ;)
Re: info
« Reply #4 on: July 11, 2013, 12:34:31 pm »
With most compilers you'll get the min and max values as predefined constants in the header/include files. Just saying :-)
    • Throw Away PIC
Re: info
« Reply #5 on: July 11, 2013, 02:40:01 pm »
Well, I definitely don't know about most compilers – you must be a busy guy to know about so many different languages and all of the various versions to make such a statement.
It's something I find handy; others may or may not find it useful.
