I'm looking for a device that plugs into a USB port and have a device under test plugged into it, plus a wire plugged into a separate laptop to receive the data.
Basically a logic/packet analyser or recorder for USB.
Are there such devices around?
What names should i google?
All i can find is software for windows, logic analysers/sniffers working via USB and scopes with decode functions.
End goal - I'm making a UHCI host driver (USB 1.0), and am at the point where it would be quite useful to be able to see what it actually does, and compare to what a proper driver does.
