Author Topic: Radio streaming to existing amplifier  (Read 543 times)
Offline TimFoxTopic starter
« on: June 18, 2024, 07:27:06 pm »
Does anyone know of a commercially-available single device that can connect through WiFi to the internet feed of a radio station and drive the AUX inputs on an existing stereo system.
The ones I found through search require an external computer or other device to do the web browsing, but I want a single box that I do not have to program past browsing to the station's website.
Offline BrianHG
Re: Radio streaming to existing amplifier
« Reply #1 on: June 18, 2024, 08:34:21 pm »
Try google: 'internet radio tuner'
Amazon turned this guy up: Internet Radio and FM tuner
Also try: https://www.av-connection.com/?ML=218
and: https://www.sangean.com/en/product/wft-4-black
« Last Edit: June 18, 2024, 08:46:29 pm by BrianHG »
Offline tggzzz
« Reply #2 on: June 18, 2024, 08:41:33 pm »
In my ignorance, I imagine the UI is important. Having a computer application would give a decent UI, and it would be useful for more than just radio.
If USB to audio is OK, then High Resolution Technologies make decent DACs, e.g. the HRT MUSICStreamer II.
I see some are available on fleabay.
« Last Edit: June 18, 2024, 08:46:27 pm by tggzzz »
« Reply #3 on: June 18, 2024, 08:59:49 pm »
The Ocean-Digital WR-10 unit found under "internet radio tuner" looks like what I wanted.
« Reply #4 on: June 18, 2024, 09:02:44 pm »
Of course, I already have computers, including a laptop I use with my TV set, including an external DAC.  I was hoping for a small single-purpose box.
Offline NiHaoMike
    • Facebook Page
« Reply #5 on: June 18, 2024, 10:20:08 pm »
You'll be best off with a Raspberry Pi or similar running open source software, see the Sonos fiasco for an example of what often happens to IoT media gadgets in the long term.
Offline themadhippy
« Reply #6 on: June 18, 2024, 10:36:18 pm »
Offline bingo600
Re: Radio streaming to exiing amplifier
« Reply #7 on: June 23, 2024, 03:07:37 pm »
If you had been in EU'land i'd have recommended a Technisat
I have a Digitradio10 IR , and i works real nice.
Digitradio 10 IR
https://www.amazon.de/-/en/TechniSat-Digitradio-Digital-Radio-Adaptor/dp/B087XNQK7Y/
Digitradio 11 IR - Afaik just bigger Screen
https://www.amazon.de/-/en/TechniSat-DIGITRADIO-11-Bluetooth-Upgrading-Black-silver/dp/B0CSPNQTNH/
https://www.technisat.com/en_XX/DIGITRADIO-10-IR/352-10774-22920/
Ohh ... Watch out - It MUST have IR in the model name
Edit :
I both have Raspi's w. DAC & a "Converted linux mediaplayer".
Both works fine, but the wife thinks they're complicated, ie. webpage login for changing channel ...
So i wanted something "standalone" with a Screen & a Remote
« Last Edit: June 23, 2024, 03:22:10 pm by bingo600 »
