Author Topic: Starlink and Co bad for ozon hole  (Read 304 times)
Offline madiresTopic starter
  • A qualified hobbyist ;)
« on: June 13, 2024, 07:35:51 pm »
Satellite “megaconstellations” may jeopardize recovery of ozone hole: https://news.agu.org/press-release/satellite-megaconstellations-may-jeopardize-recovery-of-ozone-hole/
The aluminum oxide left behind when a satellite burns up entering the Earth’s atmosphere destroys the stratospheric ozone.
Online RoGeorge
Re: Starlink and Co bad for ozon hole
« Reply #1 on: June 13, 2024, 07:42:33 pm »
Another "Elon bad" in mainstream media.  :-DD  What did he do to the establishment this time?
The following users thanked this post: amyk, wraper
Online wraper
  • Country: lv
« Reply #2 on: June 13, 2024, 08:07:23 pm »
I'd like to see any evidence how alumina damages the ozone layer as it's extremely inert. I googled a bit and found nothing other than this just released shit.
Offline m98
« Reply #3 on: June 13, 2024, 08:15:59 pm »
To link this exclusively to Starlink is obviously laughable. Interestingly, with cheap, high-capacity launchers like Starship on the horizon, aluminium might get mostly replaced by steel and (more) composites, if this issue is determined to be bad enough.
« Reply #4 on: June 13, 2024, 08:21:02 pm »
A global modeling study of solid rocket aluminum oxide emission effects on stratospheric ozone: https://typeset.io/papers/a-global-modeling-study-of-solid-rocket-aluminum-oxide-4usc5pi822
Online wraper
  • Country: lv
« Reply #5 on: June 13, 2024, 08:31:09 pm »
It's about SRBs and from what I've seen the damage is done by chlorine emitted from those which can be activated by alumina emitted from those as well.
In any case it's laughable because a few rockets with SRBs like Atlas V, Vulcan Centaur, Ariane 6, SLS will emit more alumina than all of those satellites burning, not to say chlorine and other stuff.
« Last Edit: June 13, 2024, 08:35:23 pm by wraper »
